Old 12th January 2017, 03:11 PM
I was never aware that D3s had this function.
It's only when I've seen it working on Del's S8, but then later on that day when he jumped into mine just for a quick spin around industrial estate when he pulled away "dynamically" the epb stayed engaged. Do not think the seat belt was on tho.
Will test it soon with the seatbelt on and off.
Old 12th January 2017, 03:14 PM
By the way, is there a away of coding in auto epb when stationary on the hill? I would not say I love it but definitely like this function on the A3, which has manual gearbox where this function is more appropriate, but can't see how it can harm D3 with auto box.
Old 12th January 2017, 03:25 PM
Originally Posted by Lee S View Post
EPB will only auto release if the driver has their seat-belt on. Otherwise you have to press the EPB button down. If it doesn't work with your seat-belt on, it must be faulty or need coding or something I guess.
This forum is worth its weight in gold.
Old 12th January 2017, 03:51 PM
I'm afraid not. The control module for hill hold assist is part of the ABS-ESP. The D3 is just too old, and probably so is the D4.
Is it a Bosch ABS unit in the A3?
Matt
Seatbelt on - EPB releases automatically
Seatbelt off - EPB stays on and message appears on the dis "Please release parking brake"
Exactly as Lee said
Old 12th January 2017, 03:56 PM
Cheers Matty
Honestly, I'm still due to do a first scan. Apart locking for the fuel cap which sometimes works and sometimes not (needs to be open manually from the boot) car 18 months in runs well. Can't be bother to go to dealer even if it's under warranty as knowing them this could take too much of my precious time
Old 13th January 2017, 11:22 AM
Exactly as Lee said
Yes, works as described above, been doing it all day!! I need to get a life!
Old 13th January 2017, 01:37 PM
Not on the D3 AFAIK, the D4 does this though.
Old 13th January 2017, 02:22 PM
Oh the D4 does do it. Do you know which control module in the D4 is responsible for this function? The EPB module is flashable in the D3, just imagine if new firmware could be wrote with auto EPB on a hill
Matt
Old 13th January 2017, 06:01 PM
Same here, how pathetic is our life sometimes
