Old 17th March 2012, 07:46 AM
Default DVB-T Tuner for mmi £326
http://www.ebay.co.uk/itm/Kufatec-38...item19c6823530
came across this on ebay and its fully mmi friendly and can use all the existing controls on the steering wheel ect and just plumbs in the same as the £800 job
Old 17th March 2012, 07:55 AM
Bargain, I'll have two.
Old 17th March 2012, 08:12 AM
I presume this won't work with the RNS-C that I have (to replace my analog TV tuner), even with the digital/analog tuner adapter 38323-2?
Old 17th March 2012, 08:26 AM
theres afew restrictions ie not having rear view camera means you need extra parts, and you cant have the factory analogue unit.
looks good though it has record features as well.
though if you do a search on ebay you will finf a factory hybrid for £298
Old 17th March 2012, 08:36 AM
Given that the factory analogue unit is essentially redundant in the UK at the minute, having to take it out isn't the end of the world, but if you do need to have some bits from the factory cam in there, does sound a bit of a bodge.
Old 17th March 2012, 08:49 AM
if you dont have rear view cam the extra part required is £540, that makes it more than a factory hybrid, would be worth it if you have cam but no analogue tv, but craigyb fits a new hybrids for £599 from memory
Old 17th March 2012, 10:13 AM
Just looked.. He does, but only if you have the aalogue TV. If not, then it's £899, but don't remember seeing a D3 without TV.
Old 17th March 2012, 11:21 AM
47p2's Avatar
47p2 47p2 is offline
Hmm...This is cheaper and just might work!!!
Nite Blue 3.0L SE Quattro
Old 18th March 2012, 08:08 AM
Haha well if you have av inputs then you can have anything displayed, and i have seen a D2 with sky news on the screen before but not sure if that was just part of having the digi box in there ?
Old 18th March 2012, 08:52 AM
Sky news is on Freeview but not FreeSat.
