#181
I gave all the leather another coat of leather care and then started putting it back in the car
While the rear door cards were off I swapped the triangles for some nicer ones Mike came over today and helped me finish off the interior Now thats all done, time for the mechanical stuff! Not updated the totals for a bit: 240 hours, £3412 Parts used: PS hoses (refurb, £200) PS hose brackets (used) NSF upper rear arm (used) NSF lower rear arm (used) NSF wheel bearing (used) CV boot (£12) Suspension brace (used) Boot lid (£150) FE wheels (£500) Window motor (£50) Headlight level arm joints (£15) Radiator (£300) Belt idlers (used) Accessory belt & idlers (used) Snub mount (£60) Air filter (£6) Wiper mechanism & motor (£120) Air box trim (£10) Intake duct (£10) Bumper (£200) F125 (£1) Exhaust clamps (£30) Boot grommets (£15) Brake fluid (£20) Wiper trim (£50) Platinum carpet (£25) Central locking pump (£60) Lateral Acceleration Sensor (£20) N/S seat belt (£18) Potions and microfibres (£120) Wiper blades (£30) Bosch S3 019 battery (£85) Bosch lambda sensors 2x (£120) Parking sensors 2x (£40) SAI removal plates + map (£65) Fuel pump (£140) Paint correction (£600) Dent removal (£180) Headlining & interior trim (used) Aluminium roof trim 2x (£160) |
#182
Natty little hole under the passenger armrest
Paul Gosport UK ________________________ Audi S8 2002 FE Avus Silver / Extended Red Leather. Daily Driver: BMW 3 series GT - Just more practical for my camping trips! |
#183
That's for the phone cable which plugs in to the block under the armrests. Or, used to anyway. Not a lot of use these days, since most modern phones don't fit in to the armrests.
#184
I always liked the use for that slot that one of the old members did, where he rigged it up as an iPod holder. Although finding one of those is quite challenging these days!
#185
So nothing like a USB attachment for a USB music stick that could connect in to the RNS-D unit?
#186
Funnily enough, I was looking at the phone connector yesterday and thinking that it could be reused as a USB charging point An aux input is an interesting idea...
#187
Everything removed from the top
On to the suspension - the left hand side came off no problem since that had been in bits earlier The right hand side put up more of a fight so the whole lot came off in one chunk The pinch bolt and tie rod are seized so I'll deal with those later Everything off underneath now too Empty wheel wells Just the four subframe bolts holding it in now so it can come out first thing in the morning |
#188
Amazing work!
2001 S8 (build date March 16th 2001) Brilliant black with oxblood red/black interior. Mods prior to my ownership: 01E 6 speed, carbon fiber trim, bi-xenon, aftermarket muffler with x-pipe, tinted windows, non-tip steering wheel, Spal electric fan. My mods: Oxblood red interior, LED interior lights, D3 ignition coils, new window tint, tip steering wheel with new S8 emblem, mk1 TT steering wheel air bag, mk1 TT 6 speed shift knob, new shift boot. |
#189
I love a good WITW thread
I still think MJ should have a “D2 Doctor” or “Doctored” badge that could be applied to any vehicle that passes through the workshop
2002 S8 - Irish Green Pearl. Cat N (saved by the D2 Doctor ) 1988 E30 Coupe - Royalblau Metallic 2003 S4 Avant - Light Silver Mettalic 2016 S5 Coupe Black Edition - Ibis White |
#190
That's all I've got:
