#191
I must have missed the thread on this already - I love it
Just need one for the boot lid and one for the dash instead of the Quattro badge
2002 S8 - Irish Green Pearl. Cat N (saved by the D2 Doctor ) 1988 E30 Coupe - Royalblau Metallic 2003 S4 Avant - Light Silver Mettalic 2016 S5 Coupe Black Edition - Ibis White |
#192
Mind you, there has to be an intrinsic value to carrying the D2 Doctor name so maybe all genuine MJ worked on motors need a serial number for verification.....
Paul Gosport UK ________________________ Audi S8 2002 FE Avus Silver / Extended Red Leather. Daily Driver: BMW 3 series GT - Just more practical for my camping trips! |
#193
Hmm. Noted.
Engine out: Started stripping everything off. The power steering pump will sit in evaporust for a while to hopefully allow the pulley to be removed from the hub On the separating table Easy as that Red atf Not that the 5HP cares, given that the murple did 20k on diff oil Still, I'll put the proper stuff in it. There's some crust around most of the coolant connections so all of these will get cleaned and the hoses & o-rings replaced. I left the engine and gearbox to drain overnight. They'll go on stands and start coming apart tomorrow |
#195
Getting the gearbox ready for its service. As it has been 'recently' refurbished, I don't plan on draining the diffs - the oil in them is nice and clean. However, if I flip it over to do the sump and filter all the oil will dribble out of the vents. That is solved with some 3d printed polyurethane bungs
The torque converter was rebuilt by JP Automatics in Bristol, which is a good sign After sitting in Evaporust overnight, the power steering pump relinquished the pulley with a little help from the bearing puller and the mapp torch The hub cleaned up nicely A little corrosion on the pulley is easily dealt with Engine and gearbox ready for shenanigans |
#196
This may have been asked before but is there a way of checking the oil levels in the differentials?
#197
They are filled to the bottom of the fill plug. Basically open the plug, put oil in until it overflows. This should be done with the drivetrain level so I will check and top up if necessary once the engine and box are back together
#198
OK. I have a leaky rear (must be age) so will go with the 'top up and hope' scenario at first before tackling more stuff to do.
#199
They often leak from the right hand output shaft on the rear diff. The fill plug is just behind the output flange, about halfway up
#200
PNG version picture JPG Version picture
Paul Gosport UK ________________________ Audi S8 2002 FE Avus Silver / Extended Red Leather. Daily Driver: BMW 3 series GT - Just more practical for my camping trips! Last edited by strummagnet; 12th January 2022 at 04:59 PM. |
