Old 11th January 2022, 08:00 PM
Missing a picture? Rear diffs are the same design between 5hp19 and 5hp24.
Gearbox... Why do people feel the need to sandblast these things? The end user is never going to see it, so why waste time trying to make it look 'new'? The end result is always that the steel parts just go rusty so it looks worse than ever
At least the pan is clean inside. This will go off to get powdercoated.
Nice and clean inside, albeit the wrong colour
I've filled the sump plug / fill tower with evaporust to clean this area up before it gets sandblasted, since trying to blast in here will be very difficult
Left to drain overnight. I won't be able to get all the red atf out, but I'll get enough
On to stripping the engine. Talking of stripping, the first thermostat bolt stripped as soon as I touched it
Luckily an M6 spline hammered in to it cracked it loose. These will all be replaced anyway
This engine is remarkably dry, which is nice. A little weep from the usual upper gaskets, but nothing from the crank or sump.
Most stuff removed. I'll flip it over and get the manifold and sump off tomorrow
Each time I pass the converter I give a few pumps on the oil extractor, to get as much of the red atf out of this as I can too
ID:	27642   Click image for larger version
ID:	27643   Click image for larger version
ID:	27644   Click image for larger version
ID:	27645   Click image for larger version
ID:	27646   Click image for larger version
ID:	27647   Click image for larger version
ID:	27648   Click image for larger version
ID:	27649   Click image for larger version
ID:	27650   Click image for larger version
Old 12th January 2022, 04:45 PM
Seems I was logged in on two machines and the post wouldn’t update…. Or something spooky, anyway it should be showing now
Name:	Gearbox fill drain points.jpg
Paul
Gosport UK
________________________
Audi S8 2002 FE Avus Silver / Extended Red Leather.
Daily Driver: BMW 3 series GT - Just more practical for my camping trips!
Old 16th January 2022, 07:31 PM
The gearbox sump needs powdercoating before, so I wrapped it up in cardboard and pallet wrap to stop schmutz getting in. Kersteman garage would probably just put this back in the car and send it
Cardboard down ready for cleaning the engine
Removed the oil cooler. The pipe was broken of course - split around both o-ring grooves
After cleaning the front of the engine I wrapped the crank sprocket bolt in blue roll and soaked it in Evaporust to clean it up as bit as it was quite rusty. This worked perfectly, but I didn't get an after pic
The sprocket isn't coming off as the seal is fine so no reason to disturb it. This is a very dry engine really.
Flip it over to drop the manifold off underneath so no grit goes down the inlet ports, and then pop the sump off
This is pretty crusty so will also go for powder-coat
Oh hello. Why is a piece of the cam chain tensioner in the sump?
Not bank1...
(quite clean inside given the mileage)
Bank2 upper pad - broken in to about 4 pieces. That's quite a close call! It wouldn't have taken much more running for it to spit this remaining chunk out completely and be running metal on metal.
A few chunks loose in the head
Bottom end cleaned up. Heads and valley tomorrow while the sumps get coated.
ID:	27705   Click image for larger version
ID:	27706   Click image for larger version
ID:	27707   Click image for larger version
ID:	27708   Click image for larger version
ID:	27709   Click image for larger version
ID:	27710   Click image for larger version
ID:	27711   Click image for larger version
ID:	27712   Click image for larger version
ID:	27713   Click image for larger version
Old 17th January 2022, 03:08 PM
homer simpson's Avatar
Have you forgotten to put the pics in the above post MJ?
Old 17th January 2022, 03:42 PM
Weird, I've seen all those pictures previously yet they're no longer there.....
Old 17th January 2022, 04:13 PM
FFS. I posted this in the Big Red thread without realising but was tipped off by Strum so I moved the post to this one. Apparently the forum deleted the images when I deleted the post from the other thread. I'll update it later with tonight's progress.
Old 17th January 2022, 07:20 PM
Ok, fixed the previous post
Not much done tonight. My shop vac died a while back and its remarkably difficult to clean this mess up without it.
Managed it eventually, by which time I'd had enough and came home
ID:	27716   Click image for larger version
Old 18th January 2022, 08:16 AM
What is the Kersteman garage reference? Am I missing something?
Paul
Gosport UK
Old 18th January 2022, 08:30 AM
That's the butcher who ruined the Murple. Its all in the thread for that one, but tbh its a bit of a horror show.
Old 29th January 2022, 08:24 PM
Right, back on this (again) after a bit of a wait for powdercoating due to a backlog and continued difficulty sourcing parts.
Cleaned up in here
I popped the oil pump screen off just to check there were no bits of chain tensioner stuck in it - one tiny piece so thats fine.
Sealant round the flange
Sump back on. I put new bolts on this time since the old ones are properly crusty. The sump looks a bit crunchy in this pic because of the light - actually its just some surface pitting where the rust was blasted off.
Metal oil cooler pipe
One day I will manage to stick a sump on without catching the sealant before it sets. That day is not today
Replaced the oil pressure sensor as a precaution
The old thermostat housing was such a mess I just replaced it with a good one.
Put to bed for the evening since the cam covers are off.
Cam chain tensioners tomorrow
ID:	27741   Click image for larger version
ID:	27742   Click image for larger version
ID:	27743   Click image for larger version
ID:	27744   Click image for larger version
ID:	27745   Click image for larger version
ID:	27746   Click image for larger version
ID:	27747   Click image for larger version
ID:	27748   Click image for larger version
ID:	27749   Click image for larger version
