Old 24th July 2014, 07:55 PM
Palmer Palmer is offline
Default headlight range defective
This error just shot up on my dash. Turned it on and off and was fine. Should i be worried??
Old 24th July 2014, 08:29 PM
Somerandomguy's Avatar
Could be as simple as one of the ride height sensors on its way out, VCDS will co firm and really easy to change if it is.
2004 A8 3.0 TDI Sport Brilliant Black
Came with: Black Valcona/Alcantara Leather, KESSY, rear blind, flappy paddle gear change, Phone Prep, TV
Added:Bluetooth, AMI, Hybrid TV, Parking plus, Ski hatch, towbar, DAB, Umbrella Holder, Reversing camera, Auto lights, Wheel refurb
Things to fix: Turbo fault, power drain
Old 25th July 2014, 10:31 AM
tersono's Avatar
tersono tersono is offline
Had the exact same thing recently. Started off with the headlamp range light appearing then going away again. A couple of weeks later it came back on, but this time with the air suspension warning light. As said above, it turned out to be the ride height sensor.
Current: 2003 A8 D3 3.7 Quattro
Gone but not forgotten: 1996 A8 D2 4.2 Quattro
Old 25th July 2014, 10:48 PM
Ill get it scanned then cheers folks
Old 26th July 2014, 08:04 AM
When you get into VCDS you can look at measuring blocks which show the voltage at the sensors - if one of them is 0v or varies inconsistently with ride height (requires an assistant to bounce each end of the car) then it points to the faulty end. Can just be a dodgy connection though
