Old 3rd June 2016, 04:05 AM
Artermis Artermis is offline
Originally Posted by carmel120 View Post
Hi so what does this mean I had the garage replace the sensor but this fault is still there would it be a duff sensor.1 Fault Found:
00819 - High Pressure Sensor (G65)
010 - Open or Short to Plus
cheers trev.
Morning Trev,
The cars store the fault codes unless you tell it to clear them; if you get the full fault code log it should give you the date, time and tell you if it's still detected or not.
It's unlikely the new sensor is duff, that'd be pretty harsh luck if it is; chances are the fault code just needs clearing.
If you have the necessary tools to do so clear the code and see if it comes back or not.
Current: 2004 D3 4.0 TDI V8 in Crystal Blue.
Factory: finger print, tv, xenons, keyless entry & go, soft close boot, 19s, and probably lots more besides
Done: fixed headlight washer leak, fit Bluetooth in place of factory phone
To do: DAB, DTV, fix soft close boot, get a spare key, investigate NSF bushes,
Old 3rd June 2016, 07:01 AM
carmel120 carmel120 is offline
Originally Posted by Artermis View Post
Morning Trev,
Thanks for the reply yea the fault code was cleared but it keeps returning I have changed the sensor and a ac regas.
1 Fault Found:
18049 - Please check DTC Memory of A/C Controller
P1641 - 000 -
Freeze Frame:
RPM: 0 /min
Torque: 23.4 Nm
Speed: 0.0 km/h
Duty Cycle: 0.4 %
Voltage: 11.93 V
Bin. Bits: 00101100
Temperature: 19.8°C
Bin. Bits: 00010000
Readiness: 0 0 1 1 1
1 Fault Found:
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 2
Reset counter: 254
Mileage: 184067 km
Time Indication: 0
Date: 2014.10.18
Time: 11:39:59
I was just thinking would there be a fuse related to the high pressure senor.
cheers trev
