Old 19th December 2016, 10:53 PM
H-M3 H-M3 is offline
Default rear footwell heaters
as its getting cold passengers start to complain about rear being cold. Has anyone actually repaired the heater elements or is it just replace with secondhand ones? Would prefer fix as no guarantee the SH units will last. Any thoughts??
ta
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 20th December 2016, 06:59 AM
its replace only.
you still get heat out of the footwell vents even though the electric elements are not working, after all the D3 only has them if you have the rear climate controls. All the other models make do with the usual arrangement. The heaters only add a small amount of heat, and as others have posted in the past finding a D3 with them still working is very rare. Neither of mine work, and I've not had comments from rear seat passengers when I have them. If the lower vents are cold then its possibly a stuck flap motor rather than the heaters causing issues.
Old 20th December 2016, 10:11 AM
Lee S Lee S is offline
Do they show up on a scan as being inoperative or do they just go?
Lee
2017 Nissan Leaf Tekna
Old 20th December 2016, 11:52 AM
Thanks guys. My one does have the rear climate inc heated seats. I think you might be right mannyo poss the flap might be stuck. Lee I don't have VCDS so will have to pop down to my Guru Marcin
Old 20th December 2016, 04:36 PM
If they are faulty they show up on VCDS, but the flap motors will also show.
This is what a scan of mine shows (old scan)
3 Faults Found:
00066 - Right Rear Footwell Heater (Z43)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 62
Mileage: 210468 km
Time Indication: 0
Date: 2014.03.13
Time: 18:22:12
Freeze Frame:
Voltage: 11.50 V
01087 - Basic Setting Not Performed
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 42
Mileage: 208636 km
Time Indication: 0
Date: 2014.02.01
Time: 10:41:38
00065 - Left Rear Footwell Heater (Z42)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 62
Mileage: 210468 km
Time Indication: 0
Date: 2014.03.13
Time: 18:22:13
Freeze Frame:
Voltage: 11.50 V
Old 20th December 2016, 05:39 PM
I've got two sets of these
One on the car and one in the garage.
First screenshot is a set which is on the car at the minute.
Second screenshot is of the replacement pair I have on the shelf, but only right heater has an error so the left one could ok ?? Ignore the blower fault, that's not my car's.
Why both don't have the same error?? One is 012 while the other is 004.
ID:	15296   Click image for larger version
Old 20th December 2016, 08:04 PM
Oh great..... Mine are still working then !!
Lee
Old 20th December 2016, 08:46 PM
Wow! Something my car apparently has, but I had no idea about
apologies for stealing your thread
Old 20th December 2016, 09:22 PM
Hmmm... I don't have 00065 and 00066 showing on my scans at all. I guess mine doesn't even have the electric heaters? It's a 2010MY D3 with rear climate control. Wonder why? Was it an option?
Lee
Old 21st December 2016, 11:12 PM
Originally Posted by mannyo View Post
its replace only.
How do you rectify the stuck flap then??
