Old 9th March 2012, 01:31 AM
aTOMic's Avatar
aTOMic aTOMic is offline
Default Link to my first VAGcom scan! (Part 2)
I'm sure there's a better way but...
Here is the second half.
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 03419 444 82747
VCID: 285F4EC89BE83A3
1 Fault Found:
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 33
Reset counter: 8
Mileage: 233391 km
Time Indication: 0
Date: 2012.02.16
Time: 15:18:27
Address 37: Navigation
No fault code found.
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000621300028
Coding: 0003989
Shop #: WSC 24103 444 52497
VCID: 1D316F1CC4AAEFB
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM004 0080
Coding: 0028196
Shop #: WSC 02313 785 00200
VCID: DEB3A810092C343
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040303250172
Coding: 0065054
Shop #: WSC 02353 785 00200
VCID: 275D4DF496F635B
Part No: 4E0 907 719
Component: Neigungssensor H02 0020
2 Faults Found:
01134 - Alarm Horn (H12)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 225
Mileage: 148966 km
Time Indication: 0
Date: 2008.03.16
Time: 14:41:17
00526 - Brake Light Switch-F
Freeze Frame:
Fault Priority: 3
Fault Frequency: 48
Reset counter: 4
Mileage: 233255 km
Time Indication: 0
Date: 2012.02.15
Time: 16:55:42
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 A HW: 4E0 035 223 A
Component: DSP-Amp.-High H00 0200
Revision: üˆ Serial number: h
Coding: 0000016
VCID: 1B356104DABEE1B
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H06 0060
Revision: Serial number: 00000000011192
Coding: 0010111
VCID: DDB1AF1C042A2FB
Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM004 0080
Coding: 0028196
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 B HW: 4E0 907 801 A
Component: EPB A22HC020 H02 0200
Revision: A22HC020
Coding: 0000532
Shop #: WSC 54321 210 01865
VCID: 1E336810C9ACF43
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 10
Reset counter: 5
Mileage: 234280 km
Time Indication: 0
Date: 2012.02.20
Time: 19:08:40
Freeze Frame:
Voltage: 13.66 V
Count: 236
Address 55: Xenon Range Labels: None
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
Revision: 00000001 Serial number:
Coding: 0000001
VCID: E2CB9CE03D54103
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0180
Revision: 00000000 Serial number: 304CH037520918
Coding: 0000002
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 242
Reset counter: 239
Mileage: 232717 km
Time Indication: 0
Date: 2012.01.18
Time: 12:39:17
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000012125
Shop #: WSC 03213 444 65458
VCID: 204F56E8F3D8C23
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 BOSCH12345
Coding: 303030393135313035414B564130424F5343483132333435
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 12
Reset counter: 6
Mileage: 233474 km
Time Indication: 0
Date: 2012.02.17
Time: 02:52:44
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0080
Coding: 0028196
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
VCID: DFCD95140E263DB
2 Faults Found:
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 115
Reset counter: 225
Mileage: 234531 km
Time Indication: 0
Date: 2012.02.22
Time: 14:48:16
Freeze Frame:
Speed: 0.0 km/h
Temperature: 14.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
014 - Defective - MIL ON
Freeze Frame:
Fault Status: 11101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 178
Mileage: 232727 km
Time Indication: 0
Date: 2012.01.27
Time: 15:11:49
Freeze Frame:
Speed: 115.0 km/h
Temperature: 3.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0080
Coding: 0028196
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616
Component: Telematik USA1 0050
Revision: 00000002 Serial number: 0000ATD3001323
Coding: 0000005
Shop #: WSC 03419 444 53463
VCID: E0CF96E83058023
1 Fault Found:
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0001208
VCID: E0CF96E83358023
2 Faults Found:
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 176
Mileage: 232717 km
Time Indication: 0
Date: 2012.01.23
Time: 14:26:04
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 176
Mileage: 232717 km
Time Indication: 0
Date: 2012.01.23
Time: 14:26:04
End
Old 9th March 2012, 06:56 AM
A lot of those look like the 'normal' kind of intermittent faults. I'd clear them down and see what pops up again.
