Old 2nd May 2015, 06:39 PM
Originally Posted by tipptop View Post
Yeah thats correct, you do the final level check between 30 to 40 degrees, I have the procedure, thats not the problem. Trying to figure out what fluid I need is the current headache.
Yeah, that's it
I've ordered, well garage did, oil from TPS base on VIN or number plate, can't remember, but basically they've send the same oil which was put in the first place in the factory, and again, if you don't experience serious issues, and can't really travel hundreds of miles to ZF guys to do it, then stick to like for like to avoid mixing different oils, but listen what the other guys are saying as they are more knowledgeable and experienced on this subject than me
Old 3rd May 2015, 07:14 PM
tipptop tipptop is offline
So I was under the car today to take pictures of the ZF identification plate on the gearbox. Here's the plate on the gearbox.
Here's my build code sticker.
So I have a JAY gearbox, but code sticker says I should have a JNL... Am I missing something or has this car had the gearbox replaced?
A8 D3 3.0tdi quattro 2006
A6 C5 1.9tdi 2004
A4 B5 1.9tdi quattro 1997
Old 3rd May 2015, 09:01 PM
pp
A6 C5 1.9tdi 2004
Old 3rd May 2015, 09:06 PM
So after further digging:
http://www.thectsc.com/index.php?p=p...=184&parent=58
If you look at the fluid reference table in that link it has the 6HP19A in two sections and specifies either lifegaurd6/G055005 and lifegaurd8/G060162. It says 'trans part list dependant', not sure what that means. Maybe this is the difference of software required. Dealer and etka say lifegaurd8/G060162. Why can't it just be easy
A6 C5 1.9tdi 2004
Old 4th May 2015, 05:51 PM
Drained a small bit of fluid today.
[IMG][/IMG]
Definately not the blue Lifegaurd 6+ fluid, but hard to tell if its lifegaurd 6 or 8. Definately filthy dirty, slight yellow tinge at the edges.
http://www.apra-europe.org/dateien/d...chatronics.pdf
The colour of the 3 lifegaurd fluids are shown in the above link, along with the proper fluid change procedure. Lifegaurd 6 is proper yellow and Lifegaurd 8 has a yellow/green shade.
http://www.zf.com/brands/content/en/...ange-kits.html
Anyway, I've contacted ZF directly and will wait to see what they say. Their parts list for an oil change kit linked above also specifies Lifegaurd 8. So I will see what they say as regards a software update.
A6 C5 1.9tdi 2004
Old 6th May 2015, 04:09 PM
This is the reply I got from ZF.
The following solution has been found for your request:
Hello
The only way to be certain about the oil is to speak with your local Audi dealer and have it checked against the VIN. http://www.zf.com/global/media/en_us...s/TE-ML_11.pdf
is the link for ZF oils in passenger cars. If you get an oil part number from your local Audi dealer you can reference it to the list and this will tell you if it is life guard fluid 6 or 8. If it is life guard fluid 8 then you must get the software checked and updated if needed.
So looks like the only choice is to book into Audi.
A6 C5 1.9tdi 2004
Old 6th May 2015, 05:56 PM
Ive added the ZF PF to the section sticky at the top of the thread for future reference so thanks for that
Old 5th January 2016, 01:25 PM
christer christer is offline
Hello
Please note that I just called Audi UK Customer Service and they took the VIN number, and after some investigation came back to me to tell me that they could not confirm which fluid was original fill in my car....anyone had this?
I am recently joined member, having purchased a 2007 Audi A8 4.2FSI a couple of weeks ago......
C
Old 5th January 2016, 01:47 PM
Just to add, I also just called my local Audi centre who gave me the following part nos. for:
Gearbox ATF: G060162A2 9 litres
Diff: G052145S2 1.1 litre
They couldn't even give me the spec of those oils.....
C
Old 5th January 2016, 02:14 PM
Gearbox ATF: G060162A2 9 litres = ZF Lifeguard 8 (green)
Diff: G052145S2 1.1 litre = A synthetic 75W90
I used http://www.opieoils.co.uk/p-982-fuch...-gear-oil.aspx as it has the friction modifier for Quattro already in it. It can be used in all 3 diffs. The last two digits of these part numbers is usually the size of the bottle so may vary.
