Old 3rd July 2015, 07:19 PM
Default Tyre choice and locking wheel nuts
My 4.2 Q Sport came with "good" tyres...... in that they have plenty of tread.....
It does make odd noises though and I wondered if I might have a wheelbearing or two on the way out (but impossible to tell which two!)
Then I read this
http://www.tyrereviews.co.uk/Tyre/Triangle/TR968_2.htm
that'll be it then! Haven't driven in the wet yet.......
The other issue is that they are 245/40 18 when they out really to be 245/45 (though the spare , which is a Bridgestone Potenza is also 40 section). Is a common change? Obviously it will shorten the gearing a little.
Any recommendations for good value tyres that work on an A8 gratefully received!
Of course, before I can do anything about this I have another problem to solve. It has locking wheel nuts. I have the key. But while I was just able to crack off the two fronts, which were done up to about the right torque, the rears.... are done up with a rattler gun or by a big man in a bad mood. I did manage to shift the ordinary bolts with a big breaker bar and some cussing, but the lockers..... not at prayer The key is somewhat chewed and prefers to just disengage.
Seems to be an OE Audi one - can new ones be bought?
Nick
Old 3rd July 2015, 08:00 PM
Locking wheel nut keys are easy enough to get, our sponsors will have loads for a start!
As for decent tyres, if you want to start collecting part-worn Bridgestones of the correct size I have a couple for sale: http://forum.a8parts.co.uk/showthread.php?t=9757
What area are you in?
Old 3rd July 2015, 09:14 PM
Locking nuts are uniqueish to your car, and you need your VIN etc for a dealer to order you new ones, or there are other options
http://www.lockingwheelnutremover.co...t-remover.html
http://www.jamesandtracy.co.uk/howto...ut_removal.htm
or your local tyre fitter may be able to help in return for some beer vouchers
good luck
Old 3rd July 2015, 09:18 PM
Are you sure? I thought all D2's had the same 17-point (or whatever the number is) star key? http://www.ebay.co.uk/itm/Audi-A8-D2...-/171388308518
Old 3rd July 2015, 09:23 PM
not sure specifically about D2, but when I lost mine from a leased car a few years back (a VAG Group vehicle) that's what I had to do, I believe they have a slightly different pattern, guess it makes sense really, if they all fitted the same model there would be little point in having locking nuts
Old 4th July 2015, 09:31 AM
In Somerset, about 15 miles east of M5 J25. Nowhere near HS2...... Quite interested but I'd need 2, preferrably 3 more.
Wheel nut key is the "pastry cutter" type rather than spline and has a regular pattern which means it engages in multiple positions. There are at least 5 variations of this design as I have friends in the trade who have a small collection (4), none of which fit. Will try the dealer next - after 12 years of C4 ownership they are familiar with my peculiarities (and hide if they see me coming!). I only want undo the damn things so I can throw them far, far away!
Nick
