Old 4th January 2017, 07:43 PM
Pug Pug is offline
Default Main Dealer - Goodbye
It's not often that Main Dealers take to Internet forums for advice, however...
As some of you may know (from various meets etc), I work in the service department at a multi-franchise main dealer. We recently said goodbye to the remaining VAG brands associated with the company, for sales and service.
Since we still have a huge aftersales customer base, we need a solution to replace our VAG computer tools, for 'aftermarket' products, with the main requirement being just to reset service indicators. Any other features would be advantageous since the technicians are not moving/leaving.
I made my knowledge of VCDS known to my service manager, and he enquired. So:
Whats the cheapest version or variant of VCDS?
Will it reset or adjust service indicatiors for Sèat and Skoda vehicles 2016>?
Will it have any diagnostic properties for this 'era' of vehicles.
Advice would be much appreciated.
Sean
Current: MY2019.5 Ford Ranger Wildtrak 2.0 BiTurbo
A8/S8 - A gap to fill.
Multi-Franchise Main Dealer during the day, Amateur vehicle enthusiast by night.
Old 4th January 2017, 07:52 PM
I think most of your questions can be answered by looking at the Ross-Tech web site http://www.ross-tech.com/ or making contact with them http://www.ross-tech.com/contact.php .
I'd guess you'd be looking at their Professional range: https://store.ross-tech.com/shop/cat/vcds/p/
Old 4th January 2017, 08:06 PM
Hi Sean,
Certainly VCDS can do what your service department wants from a tool. I've worked on Seat and Skoda's without problems. The Hex CAN-USB which many of us have is now discontinued, although I bet Genden still have UK stock, replaced by HEX V2 aimed at enthusiasts and limited to 3 or 10 VINs - not good for a service dept. Then there's Hex Net with unlimited VINs, a wireless tool that uses WiFi, but you're getting a bit pricy if you need a few of these. I'd certainty look out for used HEX CAN-USB cables as it will do all you want and can work with unlimited VINs at a cheap price.
Matt
Old 4th January 2017, 09:38 PM
I'm told by a friend who deals with modern stuff (I only go to ~2005) that 2016 onwards VAG models are no longer supported by VCDS. Apparently the protocols are all new and different. Might be worth confirming that with Ross-tech before buying something?
Edit - just checked the site and it appears the new Hex-Net does support the new UDS/ODX protocols. I suspect the older Hex-Can doesn't as that's what my friend and I both have.
Not impressed with their new licencing model at all
Old 4th January 2017, 09:45 PM
Yes, currently the new Q7, A4 and perhaps a few 2016 and newer MQB cars are not supported on the Hex USB-CAN.
Matt
Old 4th January 2017, 11:59 PM
Pug Pug is offline
I think the only new Seat and Skoda models are likely to be the Areca and Kodiac however due to the timing of the franchise closure, I'm not sure we will see those customers. The Ross Tech links are great thanks.
There's another member on here who has the cheaper OBD-USB version (I think), which worked with D2, D3, and D4 A8's and also a 66-Plate Audi A5. I will have to borrow it and see.
Does anyone know of something other than VCDS that might work perhaps?
Old 5th January 2017, 02:39 AM
Why are you giving up on dealer tools.
It's my understanding that anyone can setup an account to have Geko access.
I believe that is law as well. Manufacturers are meant to allow independent repair shops that same level of diagnostic ability to prevent a monopoly on fixing cars.
If you stick with dealer tools with online access you can adapt new electronic parts to cars and remove the component protection.
If your not continuing Geko subscription due to cost then Vcds would be my next logical choice.
There is also vague can pro and arbrites commander the later can also remove CP but in an offline way which I guess Vag would disapprove of.
The last two tools I only know of buy have no experience using so recommend you do some investigation
