Old 18th May 2020, 04:02 PM
homer simpson's Avatar
Originally Posted by Prefferle View Post
question: Do I now condemn the ABS module and replace with a new-refurbished unit? Any other checks?
looking forward to your thoughts on this.
Thanks guys,
I would get it tested first. No point throwing away or replacing a unit that may not be faulty
Old 19th May 2020, 10:53 AM
Prefferle Prefferle is offline
Thumbs up
Thanks Homer, I’ll do that next... putting the harness back together along with replacing brake switch again first👍
Present cars
Daily driver: BMW e65 730d
Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry.
Old 20th May 2020, 07:49 PM
Update - taped up and fitted the wiring harness along with all bits. Fitted an Audi OEM brake light switch, reset all Codes then test drove with 80+ brake pedal presses with NO FAULTS😁👍
It’s was difficult to believe that the aftermarket Febi part was an issue as Febi is a reputable brand but....😕
Another lesson learned.... Audi OEM all the way (Mabey not for suspension parts as I use Meyle-HD for years in all my past cars).
THANKS FOLKS for all your support👍
Present cars
Old 21st May 2020, 04:04 PM
Excellent news! I would also use brands like Febi but over the last few years I have read more and more posts on different cars having issues with aftermarket sensors/switches etc so I now only use original parts for anything electrical where possible.
Glad you got it sorted
