Old 18th January 2014, 04:01 AM
Very interesting considering that stock HID's use something like 1200 V for ignition and 85V when working but aftermarket unit's on ebay link use 23k V for ignition and 16-17k V when working. To be honest I am a bit surprised that it works OK with stock bulbs and they last reasonable amount of time.
Old 18th January 2014, 05:51 AM
SilverS8 SilverS8 is offline
Hi.
I will check my ballast that was taken out a H7 HID kit i was supposed to use for my C4 S6 so we can see the voltage and stuff But since they sell D2R/S bulbs in almost any HD KIT i would guess that the Ballast is the same.
Only difference from the oem setup is that it might use a second longer to heat up the bulb when starting. I have not noticed it but from having aftermarked HID in cars earlier this is usually normal.
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 18th January 2014, 06:23 AM
The attached picture is the the other ballast fron my kit. Early morning garage run
So this works
2000 Silver S8
Old 18th January 2014, 07:26 AM
I have had several of these and slim kit, I have used in my and others people cars with the H1/ H4 bulbs supplied in kit, they are 23k V start voltage and 16-17k running voltage.
OEM's are 1200V start and 85V running voltage, while you can get aftermarket kits with D2R/S bulbs I thought the bulbs would be different then OEM.
