Old 23rd August 2014, 12:10 PM
Cheers Scott
As soon I read it I jumped on it.
I left the plastic/rubber guides in, but I struggled to undo the clips with my little flat screwdriver, BUT when I got annoyed I made my own ''tool''
See attached.
With this little piece of kit clip clip knob out, same on the other switch and another 5sec later it was all done and ready to screw back.
Thank you, your guide was very very helpful
ID:	8803   Click image for larger version
ID:	8804   Click image for larger version
ID:	8805   Click image for larger version
ID:	8806   Click image for larger version
Old 23rd August 2014, 08:33 PM
Looks great...time for a mirror switch, then steering wheel buttons
Old 27th August 2014, 08:34 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Weldone mate.
You got Yellow inserts.
Never seen them before.
[center]
06 3.0TDI Quattro:
Options:
Old 1st September 2014, 11:27 AM
Would this not be a direct replacement or a parts donor
Old 1st September 2014, 11:29 AM
Following the chrome theme are these compatible
Old 1st September 2014, 11:33 AM
ScottD3's Avatar
More of a donor I'd say.
I've read about the B6 lads buying them and having issues over time and ended up swaping the switches.
Could be ok.
I'd be tempted to swap everything over and keep our original internals.
[center]
06 3.0TDI Quattro:
Options:
Old 1st September 2014, 11:39 AM
The lights switch is not OEM, ''high class of a replacement'' so it's a no, at least with me.
Window switches, single ones and mirror yeah, but not the main one, window lock button is square and our is slightly rounded at the bottom
