Go Back   A8 Parts Forum > A8 D4 > D4 - Sat Nav, ICE, Audio & TV
D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus
Old 22nd May 2016, 07:55 PM
Originally Posted by limoncello View Post
I have the one which flashes the lights on the mirror when unsafe to change lane, but not the one which nudges you back in lane if you drift. ive never had it before so wont miss it its true, but the add clearly states it has it. im not looking for him to pay for a retrofit, but theres a conversation to be had.
As for google earth i agree, i want it, its in the add, whatever it takes to get it will have to be done, this may mean paying for the firmware update or a bit more for some extra parts, but i want it.
Google earth is as easy as a firmware upgrade - even at a main dealer that will be an hours labour I suspect No hardware changes needed (if you have a SIM card slot in the dash!?) and different to a maps update also!
On the "lane assist", it sounds like your car is actually fitted with side assist.....
Originally Posted by Audi side assist including pre-sense rear (Order Code PCH @ £820 RRP in 2010)
Aids the driver when changing lane. Audi side assist monitors the area behind your
car, using radar sensors located discreetly in the rear bumper, informing the driver with a visual warning signal in the door
mirror if there is a vehicle in the their blind spot or approaching quickly from behind. The system is activated using a button in
the driver’s door and works at speeds above 19mph. If a rear collision is sensed, the upper backrest and headrest are adjusted
automatically (where memory seats are fitted) to provide more protection to the seat occupant. If Comfort front seats or
Comfort front Sports seats are also selected, the pneumatic bolsters are filled to provide more protection. The airbags are also
pre-conditioned
vs
Originally Posted by Audi lane assist (Order Code 7Y2 @ £500 RRP in 2010
Uses a discreet camera mounted at the top of the windscreen to monitor the road ahead. The driver is warned
with a vibration of the steering wheel if the vehicle is about to exit its lane unintentionally (at speeds over 38mph). Only in
combination with 4-spoke multi-function steering wheel
Old 22nd May 2016, 08:03 PM
yes i have the sim slot, its just that as the car was advertised as having google earth already, and finding that the low MMI firmware doesnt allow it any cost to make it work should be the dealers. im quite happy if its just a f/w update. im expecting that to fix it.
i have the 4 spoke wheel and the camera at the front, also have pre sense rear and front (i saw that working a couple of daya ago) but from what i can see after watching you tube clips i dont have a button or an mmi menu for the side assist. im not particulaly asking oscar to have it added but ido expect any other niggles to be sorted such as the rear blind that doesnt seem to work at the moment.
Old 22nd May 2016, 08:52 PM
If it is fitted then you will have a button on the end of the indicator stalk, if not then probably not. To be honest it was mainly an annoyance, I turned it off by default
The rear blind died in mine also, that was fixed FOC by the dealer but wasn't a quick fix and involved a long backorder for a new blind- hope it isn't the case for you.
Old 22nd May 2016, 09:09 PM
i can do without another backorder, really i dont mind as long as the car isnt languishing at audi.
no button on the stalk so pretty sure it isnt there.
Old 23rd May 2016, 08:38 AM
Side assist = lights that glow on the door mirrors to advise of cars in the blind spot, turned on and off using button on inside of the drivers door mirror.
Lane assist = button on end of indicator stalk and using camera etc. will monitor the road and alert if you are drifting out of line.
Active lane assist = above + it will perform steering corrections.
They're all fairly unnecessary in fairness, just expensive options that Audi punt out there so Joe public can beta test tech that will presumably, ultimately become essential to fully automated driving....
As you have Adaptive cruise with the camera already, Lane assist should be only a stalk change and coding change i believe. Having read Oscars advert I did think you had it, and it was noteworthy as being the only difference I think between yours and mine....
Old 23rd May 2016, 09:07 AM
i quite like the side assist
but i have no button on the stalk, its not that i cant live without it, i wouldnt bother retro fitting it, it was advertised though.
I think that makes our cars virtually identical, i cant see a difference in the pics you put up and mine. colour, interior , and equipment look exactly the same
