Old 28th December 2018, 08:04 AM
CrozA8's Avatar
CrozA8 CrozA8 is offline
Default Elsawin problem-Help please
Hello all, I run Elsawin 4.1 with the upgrade and have had computer issues which required me to re install. The Elsawin side was installed OK but my Audi data disc seems to be cactus. This leads into the next problem as I was going to use Elsa to help me replace the rear wheel bearings, now I need help.
Can someone assist with either an Elsa Audi data download or the Elsa procesdure for the rear wheel bearing replacement on a 2006 D3 A8 BFM.
Thanks in advance.
2006 A8 4.2 Ltr Silver Green 20" Factory Alloys
Old 28th December 2018, 08:36 AM
Can't help you with the data download I'm afraid but the procedure seems to be in the D3 'tech dump':
http://forum.a8parts.co.uk/showthread.php?t=9347
Document #39 looks like the one you need ("Service Manual Running gear front-wheel drive and four-wheel drive"), specifically around page 147:
http://forum.a8parts.co.uk/attachmen...9&d=1420367776
Old 28th December 2018, 09:21 PM
CrozA8's Avatar
Thanks Mark, you know I looked in the tech dump but must have breezed straight over the top of it: Confused:.
Thanks again.
Chris
