Old 22nd April 2016, 02:35 PM
A8Pete A8Pete is offline
Default Cant enable hidden green menu
I have just tried via VCDS to enable the green menu
I went into VCDS
selected module 7 head unit
then selected adaptation 10
then selected channel 8 and read values
Then I get an error "channel 8 not available"
Am I doing something wrong?
My car is an 2004 A8 4.0 Diesel.
Many thanks
Old 22nd April 2016, 03:16 PM
thats correct, try to enter a "1" in channel 8 and click test
Old 22nd April 2016, 03:37 PM
Will do.
Old 22nd April 2016, 04:06 PM
Here's 3 images from the VCDS
- the 08 err
- entering 01
- then presing test for 01
Name:	mmi_01 (Medium).jpg
ID:	13217   Click image for larger version
Name:	mmi_02 (Medium).jpg
ID:	13218   Click image for larger version
Name:	mmi_03 (Medium).jpg
Old 22nd April 2016, 06:34 PM
i noticed that a6's use chan 6, some have reported chan 5,
are these also greyed out
whats the coding on you [07] module?
Old 22nd April 2016, 06:36 PM
I just re-uploaded the pictures. The last ones weren't clear.
What do you mean by "whats the coding on you [07] module?"
Old 22nd April 2016, 06:45 PM
when you do a scan with vcds you get an output for each module
such as this
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 300GL047537256
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 3A7EB5AE7544B83
Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
No fault code found.
note the coding is 000002
these are options that can be changed, for each model depending on what equipment you have installed
its probably not this one that has the av imputs though check out also the tuner coding.
i have had a quick look through the green menu and cant see anything obvious.
Old 22nd April 2016, 07:07 PM
coding for the [07] control head is 0000002
coding for the [57] tv tuner is 0001003
Old 22nd April 2016, 07:11 PM
Ok on the control head 07
what is the result of looking at channel 11
Old 22nd April 2016, 07:29 PM
Do I have to got to module 07, then channel 10 adaptation, then enter 11 and click read?
(sorry Im new to all this)
