Old 16th November 2022, 10:27 PM
sarg sarg is offline
good job for the work and not giving up, not enough people do their own work on these
Not enough people have the necessary skills (me!) and/or tools and/or workshop space
2019 BMW M5 (my daily driver)
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 23rd November 2022, 04:52 PM
Looking forward to the update on the poly bushes. Great work.
Old 30th January 2023, 05:55 PM
Lunamar Lunamar is offline
Default What is the process of aligning the rear subframe
Are there pins or something as a guide like for the front subframe?
Old 30th January 2023, 06:40 PM
Ronin Ronin is offline
Yes there are 2 of them, i think MikkiJayne made some.
Old 31st January 2023, 01:08 PM
scottmgibb scottmgibb is offline
When I had my car aligned after I did all the work, the position of the front subframe was adjusted slightly to balance out the camber. I guess if you used locating pins then you would not be able to do this (and there is no other stock way of adjusting this). Of course if I had used locating pins then maybe it would not have needed to be adjusted…?!
Audi S8 D2 2002
Old 31st January 2023, 02:08 PM
The locating pins for the front and are just to get it in the factory default position. They almost always need moving afterwards to get camber and caster correct, so if yours just needed slight adjustment you must have eyeballed it pretty well The pins come out afterwards.
The rear doesn't have pins. It has sockets in the rear mount hardpoints, but the sockets are slightly larger than the hole in the bush so I'm not quite sure what the factory tool looked like for these. I 3d print one-use bushings each time I do the job, and they just stay in place sandwiched between the subframe and the body. Aftermarket bushes that I've seen tend to be even smaller than the factory ones so there's no way to get a tool out again afterwards.
Old 1st February 2023, 08:28 PM
NLA rear trailing arm shock absorber bush is back in stock on autodoc. I suggest anyone planning to do a subframe refurb to get 2 before they dissapear again:
https://www.autodoc.co.uk/febest/14133184
Old 25th February 2023, 09:21 PM
new old stock rear diff mount assembly:
https://www.ebay.co.uk/itm/364107695...Bk9SR4KYj6vRYQ
