Other Audis All other Audi related chat |
C5 Allroad Injector Refurbishment
I've stuck this here as it is the car I've done this on. However, the injectors are used on the 3.7and 4.2 used in petrol D3 A8s and the principle is the same for most petrol injectors pre FSI.
I was getting codes showing the offside bank was running either rich of lean to various degrees and having done a full service and changed the spark plugs, the next thing was a failing injector on that bank. I bought a second hand set of injectors from a D3 and had them cleaned and tested. All were within tolerance so I bought a refurbishment kit from Master Injector on eBay. The kit contains 8 X filters, 16 X o rings and 8 X plastic washers to hold the lower o ring in place. First remove the old o rings a plastic washer. Pin nose pliers pull the plastic washer off easily. Next remove the old filter. I used a blunt self taping screw and pliers. Screw in to the filter until it just bites and pull the filter out with a bit of force and a wobble action. Insert the new filter and gently tap it in until it's flush. I use a small wooden mallet. Fit both the o rings and the plastic washer on the bottom. They all just push on. The plastic washer will rotate once on properly. Repeat 7 more times. Then reinstall. My reading suggest that injectors should be cleaned and tested every 125 to 150k. The refurbished injectors cleared all the faults on VCDS.
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. Last edited by Conan_the_Librarian; 23rd August 2021 at 09:45 PM. |
Part nos?
Nice Mike - have you got the part number for the Thatchers Gold?
Autos Autos everywhere... (1) 2015 Tesla Model S: (was 85D, now 90D ). Silent and deadly, and very fast... But not as fast as Ian's M3P- (2) 2002 D2 S8 Final Edition: Bulletproof and faultless: Brilliant Black with Extended (Red!) Leather. Three-times winner of Best D2 1st prize (3) 1997 Fiat Coupe 20v Turbo: Scots (! ) Green. Fragile, but beautiful. (4) 2010 Fiat Panda 100HP. White Pandamonium (Final Edition!!). Pure old-fashioned 6-speed go-karting. |
I buy them in bulk. 24 to a pack with a price break point at 5 packs. Last about a week when I'm working on the cars. 4 months if I'm not!
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
