Old 1st June 2019, 03:58 PM
Those look rather nice. I like the description in the link
I really need to re-do all of mine since it's never sounded quite right.
Although... now I'm wondering if I should check the polarity of the speaker wiring. I think I just assumed a wiring convention that may not be correct, which won't be helping.
Old 1st June 2019, 07:17 PM
Markiii Markiii is offline
defo start with that. what speakers did you use last time?
Old 1st June 2019, 08:07 PM
I still have the Bose speakers in the doors wired in to my PG Route66, and a couple of Infinity Kappa subs in the boot. When I wired the amp I assumed the door speakers were colour stripe + and brown stripe -.
Old 2nd June 2019, 04:07 PM
johnny_quattro's Avatar
Originally Posted by Markiii View Post
Always had a softspot for Genesis amps and managed to track down a Genesis Profile 5 which looks like it will be a perfect fit in the area the stock CD Changer used to sit
[IMG][/IMG]
With regard to Genesis amps, Gordon is the person to go to. He runs ampdoctor dot co dot uk and he's fixed a few of my beefy JL Audio amps in the past. I gather he had a lot to do with Genesis in the past. Just mentioning it in case of problems with the amp.
Cheers.
Old 2nd June 2019, 09:06 PM
That's handy to know ^ My Route 66 needs some TLC I think.
Old 2nd September 2019, 04:24 PM
Teaser: 6.5" speaker in the front door...
ID:	22103   Click image for larger version
ID:	22104   Click image for larger version
Old 18th November 2020, 01:49 PM
Head unit now installed
ID:	24569   Click image for larger version
ID:	24571   Click image for larger version
Old 19th November 2020, 04:34 PM
for anyone interested its an Android 8.1 Octacore unit with a 9" IPS screen
and it has SPDIF digital out ready to connect to the processor thats next on the list
Looks like its now been updated to Android 10
https://www.joyingauto.com/joying-2-...roid-10-0.html
Old 19th November 2020, 05:18 PM
Interesting unit. Is yours all glass on the front? The one in the link looks like it has a separate bezel round the screen.
Just wondering if the screen could be fitted in to a custom housing the same shape as the hole in the dash...
Old 19th November 2020, 05:41 PM
possibly, its not far off fitting as it is, needs a few mm off the top and bottom of
the frame
I did contemplate sanding it but didn't feel brave enough to risk the screen if it didn't work. visible screen doesn't of all the way to the edges but it looks like one single panel
