Old 5th February 2021, 06:42 PM
S81 S81 is offline
Correct,that's a pic of one i took out to change oil ring ,i had difficulty getting them out as I didn't want to grip them with pliers so I very gently levered with a screwdriver whilst turning back and forth and pulling them they came out
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 5th February 2021, 07:45 PM
Kazs8 Kazs8 is offline
Thanks S81 appreciate your help, today I fitted a new right side rocker cover which comes with gasket, also replaced o ring on one solenoid one which fits in through the cover but still have oil leak, after closer inspection looks like it’s coming from around the solenoid housing so the o ring a purchased from eBay must have been wrong size. Will have to go to local dealers to get correct o ring.
Just to add the inlet solenoid seems fine/dry
So didn’t see any point in touching that.
Old 5th February 2021, 09:00 PM
S81 S81 is offline
My vvts weren't leaking but I have car off road for winter and am doing preventive maintenance as I'm going to drive it over the summer and don't want to be mechanicing then, i have changed rocker cover gaskets( had oil leaking into the plug wells in both sides) ,and vvt o rings (o rings were hard on all 4),and I've removed the manifold and currently doing a carbon clean and few other jobs ,vvts were easy to get at with manifold out
Daily driver
Previously owned
