Old 4th February 2021, 08:59 PM
S81 S81 is offline
Default Oil pick up pipe in the sump
has anyone removed the sump and checked /cleaned the oil pick up pipe gauze and if so is there anything else that should be done when in there and would you have the torque setting for the sump and pick up ,i've check but can't find
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 5th February 2021, 11:58 AM
I found the following settings for the sump bolts, which I've reproduced exactly (as I don't understand the difference):
Sump (Lower bolt(s))
Stage 1 - 5Nm
Stage 2 - 9Nm
Sump (Upper bolt(s))
Stage 1 - 5Nm
Stage 2 - 90 degrees
Can't find anything for the pickup.
While you're at that end of the engine, the oil drain plug is 25Nm.
Obvious question (for MJ) as I've never dealt with sump bolts before, but are those values so low because of the thinness of the metal used for the sump, to avoid distortion?
Old 5th February 2021, 12:43 PM
That's normal for an M6 fastener, in aluminium or steel. I would have said 10Nm without looking it up, and yes two stages is to avoid distortion. Usually that'd be done in a diagonal pattern to pull it down evenly. I don't measure the first stage since spec on a D2 is just final torque, so I nip them up by hand first then follow with the torque wrench.
The 5+90° is the same as the cam caps in the D2. They're trying to achieve a specific amount of tension on the bolt with the 90°, as an angle is more accurate than a turning torque. Usually an angle signifies the bolt is torque-to-yield (stretching past its elastic limit) but that spec isn't enough to stretch a high tensile M6 bolt (I've measured used against new) so its just done for accurate tension.
Old 5th February 2021, 05:44 PM
S81 S81 is offline
Thanks Sean and mj,i'll let you know who it goes
Daily driver
Previously owned
Sorry to jump in here MJ but when I did mine (AMX 2.8) I used the Elsawin guide and no reference to addtional 90° just 10NM. Now I am a little worried as after fixing took the car for a mini Italian tune up to Brixham and back!
Name:	E Win Snip.JPG
Paul
Gosport UK
________________________
Audi S8 2002 FE Avus Silver / Extended Red Leather.
Daily Driver: BMW 3 series GT - Just more practical for my camping trips!
Old 6th February 2021, 11:23 AM
The torque settings being referenced in the post are for the 5.2 V10 engine.
Old 12th February 2021, 06:15 PM
S81 S81 is offline
Sump of and all looks good ,the gauze look to be perfectly clean ,i removed the arb to get acess to the row of rear bolts and it made it straightforward
Daily driver
Previously owned
Old 12th February 2021, 06:17 PM
S81 S81 is offline
Ps the metal pipe in the pic is attached to the bottom of the rad with 2 screws ,and it's very badly corroded at one point does anyone know part no or have exploded diagram for it please
Daily driver
Previously owned
Old 12th February 2021, 07:38 PM
If you can identify the pipe in the following PDF, I'll check for a part number as the illustration in the parts catalogue has a host of pipes. Section 19 is the relevant part to look in.
11-Service Manual 10-cylinder direct petrol injection engine (5 2 ltr 4-valve BSM) mechanics.pdf
Old 12th February 2021, 08:37 PM
S81 S81 is offline
It's called the bottom front coolant pipe in the 3rd pic down Sean ,i'll have another look to see if I can find a better diagram with it
Daily driver
Previously owned
