Old 9th May 2010, 07:47 PM
Duffy Duffy is offline
I've got Brembo's they're bolted in place rather than a pin job (In other words they're fixed, not floating).
Thanks for the suggestion though
Old 12th May 2010, 10:34 PM
Check ur lower ball joints....The grease leaks out and causes a clunking noise....meant to be common problem on d2...ssss
Might be wrong but it is a relatively cheap fix....
Old 12th May 2010, 10:43 PM
Mr K Mr K is offline
Duffy, I have replaced all mine with Meyle HD bits, they bassically heavy duty versions of the standard parts. iirc they have a good warranty on them.
I did however use lemforderd (sp?) arb links, theese appear to be OEM with the audi rings ground off - they are completely identical except a small area of grinding where the badges used to be...
I wouldnt bother with audi ones on the cost basis and becuase i beleive the above two companies are equal too or better. I would avoid really cheap ones though, if its not a brand you have heard of ask on here, its not a job you want to do twice.
The guys are All German Parts will hook you up with some quality stuff, ask for a discount and they should knock a bit off too.
I assume your talking to Duffy? mines all new. weirdly my clonk has got less frequent! still waiting on my new poly ARB bushes from poland, will do a how too and a review when they turn up - might be a good little upgrade, might be a waste of time! we will see...
Old 12th May 2010, 11:37 PM
I didn't even make the above post
Old 13th May 2010, 09:50 AM
Confused!
It's posted from your profile...
Old 13th May 2010, 10:25 AM
builder22 builder22 is offline
Do we have a security issue maybe?
Gone, but not forgotten...
2000 A8 4.2 Quattro – Green, S8 18’s, Xenons, PhatBox, and loads of other toys.
Old 29th July 2010, 10:19 PM
fixed... http://forum.a8parts.co.uk/showthrea...3678#post13678
