Old 9th June 2018, 06:59 AM
madcjd madcjd is offline
Default Roof trim removal
Re the 2 alu strips that run the length of the top of the roof.....(2005 D3 model)
Has anyone removed one?
Mine has paint flaking and ideally needs to be removed to be primed/painted.
I'm guessing there are clips that possibly get damaged upon removal?
Previous cars
A8 D4 4.2tdi lwb (2011)
T5 Caravelle exec 2.5 (2006)
A8 D3 4.2 quattro (2003)
A6 4.2 quattro avant (1999)
A6 2.8 quattro (1998)
Audi Coupe 2.6E (1993)
Carlton 3.0 GSI
Old 9th June 2018, 03:45 PM
Just pull up carefully - they will bend easily but can be worked back into shape
Old 10th June 2018, 06:57 AM
Ok, thanks.
Did you remove yours for the same reason?
Previous cars
Carlton 3.0 GSI
Old 10th June 2018, 07:58 PM
Yes, seems a common issue....
Old 16th June 2018, 12:27 AM
H-M3 H-M3 is offline
One of my one has failed too what are they new rather than faffing about? Also can you take any pics when tackling the task. Cheers
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 5th July 2018, 11:17 PM
Did you repaint yours buddy?
Old 13th July 2018, 04:55 PM
roberto's Avatar
roberto roberto is offline
Default no real answer to the original question here ?
i want to remove mine too but only to remove the black wrap
so please are there any clips ?
and where do you start to pull from of lever out ?
ta
Old 13th July 2018, 05:06 PM
ta
Start at the front or the back, lever or pull upwards and work the length of it out....
Old 13th July 2018, 10:51 PM
ta
Please take some pics.
Old 15th July 2018, 02:25 PM
roberto's Avatar
Default Trim removal
just as Paulrstaylor said above
so
no need for pics its easy
you need a small plastic trim removing tool same or smaller width as the trim
lever it up carefully from the front near windscreen
there are no clips
its a long rubber trim from 1 end to the other built into the trim
honestly very easy just take your time and move along slowly pulling from as close to the roof as possible
Black wrap roof gone !
