Old 2nd April 2016, 12:55 PM
So, do you think a carefully positioned full bottle of water resting on the seat switches could be the cause!?
Wondered why the seat position was so far off this morning...could barely get in the driving seat.
Wonder also if the motor is now screwed .....
Shirish: 2001 S8
Old 2nd April 2016, 12:58 PM
Lee S Lee S is offline
Naaah. Surely there is an "end of travel" micro-switch that will cut power to the motor when it reaches its end-stop?
Lee
2017 Nissan Leaf Tekna
Old 2nd April 2016, 01:01 PM
good shout, but kinda hoping there isnt and this is the root cause!
rac man here shortly, will hopefully get a load test on the battery and see whats what.
Shirish: 2001 S8
Old 2nd April 2016, 04:04 PM
Just tested, motors stop at limit with buttons held down, but presumably there is still some drain from the control circuit. Should be minimal though.
Old 2nd April 2016, 05:17 PM
thanks for that, time to look elsewhere.
RAC man come and gone - suggest battery is ok, however a possible large drain detected. Unsure if this was because the car hadnt gone into sleep/shutdown mode when the test was started (how long does it take to go into shutdown mode?)
Comments Suspected Diagnosis:
battery flat - charging/starting system tested ok. advise 40min drive to charge and 24hr trickle charge to
fully recover battery.
no load drain above acceptable limit after 5mins, advise further investigation at garage asap.
Battery Test Results
Battery Test
Battery Manufacturer: BOSCH
Rating of battery tested: 720EN
Chemistry of battery tested: FLOODED
Rated Ah of battery tested: 90
Smart charge: No
Time: 02/04/2016 14:55
Temperature: 22.2°C
Measured voltage: 2.61Volts
Measured rating: 202EN
State of health: 40%
State of charge: 0%
Test Result: Good Recharge
System Test
Jump pack used:Yes
Starter Avg voltage: 8.03Volts
Starter Avg current: 173.9Amps
Starter result decision: Charge Battery
Alternator voltage (unloaded): 14.02Volts
Alternator voltage (loaded): 13.56Volts
Alternator current (unloaded): 22.7Amps
Alternator current (loaded): 17.2Amps
Charge acceptance test performed: Yes
Diode decision: Normal
Alternator test decision: Norma
l
First drain test voltage: 2.61Volts
First drain test current: 0.1Amps
Second drain test voltage: 12.06Volts
Second drain test current: -0.9Amps
Shirish: 2001 S8
Old 2nd April 2016, 07:16 PM
I've got pics of mine in a fairly heavily dismantled condition to access the battery! Boot side trim off and moved to the centre and trim by boot catch removed too
I didn't feel confident keeping everything out the way on reassembly without stripping it that far and it dropped in very easily.
A helping pair of hands or HP's approach would be alternatives but getting it out single handed would be a struggle through that tiny hole
Old 2nd April 2016, 08:57 PM
green A8 green A8 is offline
I'd suggest you check the state of the positve feed 'junction box' where the wire splits and feeds the alternator and starter motor. This is located on the O/S chassis leg as is a troublesome earth lead, which can also cause problems. I havn't got any photos of these parts, perhaps others can assist, but I know that just these two connections/wires can wreak havoc when they become corroded.
Old 3rd April 2016, 07:10 AM
Pics of battery compartment access:
Note that tail light removal is not required! I happened to be in there doing that a couple of weeks before the battery died....
ID:	12964   Click image for larger version
ID:	12965   Click image for larger version
Old 3rd April 2016, 08:00 AM
All looks very familiar. Pretty sure I swapped over OK without removing the side trim though, but it looks like it would make it a lot easier.
Old 3rd April 2016, 08:18 AM
thanks, I will. I did get (ask) the garage to do this during the first service in my ownership last year however worth checking again.
Battery undergoing a full recondition charge on the ctek - should be done later this afternoon, however unsure I'll get time to follow Dels procedure that he kindly uploaded.
Shirish: 2001 S8
