Go Back   A8 Parts Forum > A8 D3 > D3 - Common Faults
D3 - Common Faults Quick links to all known common faults and their solutions
Old 1st September 2017, 10:04 AM
North2007 North2007 is offline
Default Fault ABS Sensor Rear Left
Guys, this fault came up recently. Results in the ESP/ ABS warning lights and deactivated park brake. After changing the sensor, fault still there. Used VCDS to establish fault came up before wheels turned. Turned out a bad connection at the terminal ABS pump up front. Cleaned up the male pins, reconnected and fault gone.
2003, A8 D3 4.0 TDI
Old 7th December 2017, 06:00 PM
lordchris lordchris is offline
Thanks for posting.
I have a similar problem with front left. Have changed the sensor to no avail, I have a vcds log what would I be looking for for similar root cause ?
Old 7th December 2017, 06:20 PM
Did you check plug loom connecting to ABS pump?
2003, A8 D3 4.0 TDI
Old 7th December 2017, 07:10 PM
Not yet
Need to check :
Pins into sensor
Wiring to sensor
Plug loom - is this just the wiring?
Waiting for toddler to get to bed and hopefully I’ll get the car into the garage for a look! If it’s the cable moving it by hand should trigger the fault ?
Old 7th December 2017, 07:25 PM
If the fault comes up on start up before moving it’s the sensor, wiring or pump. If it’s triggers on rolling, it’s the ABS ring. Moving the loom may not trigger it.
2003, A8 D3 4.0 TDI
Old 13th December 2017, 09:10 PM
Sensor changed, fault back. Vcds showing faults with control module.
Confirmed by local mechanic. Came on this morning going over a speed bump.
Check pins?
