Old 20th February 2017, 12:59 PM
Well, I'm still having my brake pad warning so I will just do the calibration again with the current thickness so to completely eliminate rear pads.
I've had both wheels off and traced all the wires and they seem to be intact and secure, but that was a quick look.
Old 20th February 2017, 01:28 PM
I really hope its not the issue I had with my 2005 D3 A8L where the brake twisted pairs of wire to each wheel had an issue with the outer casing getting brittle, so the brake wires can end up touching. If it is just a brake pad warning then hopefully its not that. I ended up having to replace each twisted pair all the way from each wheel to the brake ecu
