Old 6th May 2013, 08:21 PM
The FL Bose is mounted side on too interestingly enough, but doesn't look like it sticks out as much.
Old 7th May 2013, 02:20 PM
Wow yes, those B&O ones are bigger.
While you are in there, do you see a mechanism comprising or a 90˚ gear with cross-cut nylon teeth about 1" dia.
It looks like you wind it with a hex tool and it drives a verticle shaft which disappears down behind everything.
It is between the rear light and navi/radio/tv/amp assembly.
I saw this on mine and wondered what it is for.
I turned it a few times, but nothing happened.
Old 7th May 2013, 03:49 PM
Yes, now you mentioned it.... I had forgotten.... Was on a bit of a time constraint at the time so couldnt investigate but know exactly what you mean, and I'm equally unsure... !
Old 13th May 2013, 07:28 PM
Chin's Avatar
Chin Chin is offline
Can you retro fit the fridge ? Also , if I haven't got a fridge can I still swap the pop up middle headrest for the shot glasses holder type headrest ? And has anyone got the part number for it
Silver Violet A8 L W12
Old 13th May 2013, 08:55 PM
Yes, i think the fridge can/could be ordered as an aftermarket kit....
Re glasses holder, maybe its possible, but finding the parts, in the right colour from a donor car doesnt sound easy or cost effective to throw away the rest of the fridge... !
Old 15th May 2013, 10:45 AM
Chin's Avatar
Can you not get the parts from TPS ?
