Old 12th July 2018, 02:10 PM
In the case of the Dension, there is nothing to see. Its a blue box the size of a fag packet with some wires coming out of it which tucks in behind the head unit. If you want to use the USB port then you could run an extension cable under the centre console in to the armrest. The same probably applies to the xcarlink.
Old 12th July 2018, 02:15 PM
My D3 Dension is under the back of the glovebox so you can reach it with a USB stick and/or inputs etc and it seems to work fine there
