Old 17th November 2015, 01:38 PM
Camspec in Manor Royal, Crawley. They bought the kit earlier in the year
Old 17th November 2015, 01:41 PM
Matt
Old 17th November 2015, 04:04 PM
That is worth knowing, Adrian.
My last CP was done by Swindon Audi for £60 on a Saturday but it was organised by Guy so was probably a special.
Old 17th November 2015, 04:10 PM
yes they normally charge £90 to end users at Swindon Audi
Old 25th November 2015, 09:07 AM
Conquistador's Avatar
I contacted Audi about this issue. Their response is as follows:
"Just getting in touch about your enquiry on the dash from the other day. My warranty colleague has confirmed that your vehicle did have a control panel replacement carried out in its warranty days and we have cross reference the part that was replaced against the part on ETKA which shows the same part number on both. The suggestion that my parts manager made for a final way of putting your mind at rest about this one is for you to remove the panel to expose the part number on the back in order for us to do one more check and make sure that the panel matches the part numbers we have on the warranty claim.
I have been advised also that there is not more than one panel available for this reg, neither is there any supersession/modification to the parts."
__________________________________________
Looks like I'll be taking the panel out then to check its part number. The panel with heated seat buttons should be 4E0820043G. I can't find a part number anywhere for a control with 'AC' button.
The bottom line is that the car is definitely missing the factory function of that 'SETUP' button which is preventing me getting into this menu. Quite critical at the moment as the centre vents are blowing a bit cooler than the outer vents so I assume the setting is turned right down:
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 25th November 2015, 09:20 AM
The bottom line is that the car is definitely missing the factory function of that 'SETUP' button which is preventing me getting into this menu:
Sometimes the full Hardware number is available with a VCDS scan. The HW usually is the part number. Try a scan first before resorting to taking panels out.
Matt
Old 25th November 2015, 11:05 AM
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000106345
Coding: 0057465
Shop #: WSC 02313 785 00200
VCID: 1C373B69DFDF87C1927-8049
No fault code found.
Thats from my car with the setup button. Prefacelift
Matt posted a picture with the part number for the unit with AC button on the first page, but having looked through ETKA there seems to be quite a few different options mostly related to ventilated seats, massaging etc, A vcds scan should be enough to get a part number from it then you can speak to Audi about a replacement if it was them that supplied it incorrectly, List price is over 800 ��
Old 25th November 2015, 04:10 PM
Just for comparison, here is mine:-
2004 A8 D3 3.0TDI Pre facelift.
Part No SW: 4E0 910 043 A HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 016 0300
Revision: 00000025 Serial number: 00000000042459
Coding: 1067019
Shop #: WSC 02311 785 00200
VCID: 1B35FB59DA40ADE6A3-804E
Main difference is the suffix letter.
Old 25th November 2015, 07:43 PM
Joe2.0E Joe2.0E is offline
Seems very likely that the incorrect part was fitted at the time of the warranty claim which means Audi will have to sort it for free if you can prove it.
It would very unusual that it would have been replaced twice given that its a part that rarely gives trouble. Fingers Crossed.
Old 25th November 2015, 07:57 PM
Control Module Part Number: 4E0 910 043 C
Component and/or Version: KLIMAAUTOMAT 017 0060
Software Coding: 0090365
Work Shop Code: WSC 00759
VCID: 1D37AF2FC4331CF6901-8048
Additional Info: 4E0910133 FHS H03 0070
Additional Info: Geraet 184863
Advanced Identification
Serial number: 00000000165003
Identification: BHB-001
Revision: 00000037
Date: 09.07.09
Test stand number: 0001
Manufacturer number: 0128
Misc.
Hardware number: 4E0 820 043 K
VCDS Info:
Labels: NONE
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
