Old 3rd April 2012, 07:59 PM
A8_Tony's Avatar
A8_Tony A8_Tony is offline
Hey snapdragon. I spend a lot of time in Nottingham, whereabouts are you located?
A8OC Founder
The A8 Owners Club here
Old 3rd April 2012, 08:00 PM
Originally Posted by A8_Tony View Post
Easy retrofit though? & what's the part no
Nope, **** and a half. Mileage correction is the biggest problem, making second hand ones tricky to get in. Note each cluster is different per engine, as different redlines etc.
New is the easiest way to go, but expect to say goodbye to a grand.
Biggest reason retrofitting ACC is a pain....
Old 3rd April 2012, 08:01 PM
What operating differences are there on the narrow and wide ones?
(Notwithstanding ACC) Just longer red lines?
No, its quite good - Navigation is bigger, track names for MP3's on top line are way longer with more detail, and any warnings, fuel, low washer fluid etc get put in the top right hand corner out of the way, so you still get all the usual detail.
Its defo worth having....
Old 3rd April 2012, 08:09 PM
Thanks, maybe one day if the price is right and I overcome the security restrictions.
Hello Tony, how do I know you aren't from the government?
I work in Clifton which has £1.2M worth of speed humps, but live near Woodthorpe.
Old 3rd April 2012, 08:45 PM
audiforum.us/threads/adaptive-cruise-control-acc-retrofit.13441/
has a load of info.
Old 19th November 2012, 12:32 PM
sticks_a8 sticks_a8 is offline
is this an acc car
56 reg
Old 19th November 2012, 02:31 PM
Could well be... Key giveaway is (as they all got the wide DIS at one point I think). Is there a square blanking panel on the bottom grille at the front.. If so, then yes...
Old 19th November 2012, 02:43 PM
http://www.autotrader.co.uk/classifi...code/logcode=p
this one cant see any square box
Old 19th November 2012, 02:44 PM
Shame on you PsYcHe..
You can clearly see there is no switch on top on the cruise stalk for distance regulation, so this car does not have ACC and is likely a later facelift model with factory widescreen DIS..
Old 19th November 2012, 03:14 PM
< holds head in shame >
