Old 2nd March 2015, 05:30 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Originally Posted by Duffy View Post
It might be a sensible idea for this thread to be either amended or closed as I bought those LED's on the recommendation from here.
I'm going to wire up a holder and give it 12V later on and try to measure some temps to work out how serious a problem it is.
Good idea Duffy.
2007 Mini Cooper S R56
Old 2nd March 2015, 07:26 PM
I did a test rig with a CANBUS error free LED and an incandescent 501 in parallel.
I did not take any temperature readings but found after ten minutes I could hold the incandescent but not for long whilst the CANBUS LED actually burnt my finger just touching it.
Please let us know your results.
I was reading a couple of weeks back about a guy in the States who was playing with PTCs to solve this but seems to have gone quiet since. Hope his house did not burn down
Old 2nd March 2015, 07:37 PM
Duffy Duffy is offline
Wildo
1988 Audi 90 2.2E
2011 Mercedes E250
2016 Abarth 595 Competizione
2012 Porsche 981 3.4S PDK mid life crisis!
Old 15th March 2015, 06:04 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
More interior LED goodness here and more about Trups and his wonderfull LEDs.
http://forum.a8parts.co.uk/showthread.php?t=8131
[center]
06 3.0TDI Quattro:
Options:
Old 15th March 2015, 09:13 PM
I went the Trups route after chatting with Scott and am really pleased with the result.
I had two problems:-
1 The rear footwell lights would not come out for me but Trups did it rather quickly when I was visiting him.
2 The number plate light screws are solid so when the warmer possibly drier weather comes along I will get the drill out.
Trups did my front side lights with his little loom and they look fantastic.
Trups did me a special but there were other things in play that helped both of us.
I do reccomend his kit, especially the door/boot & footwell LEDs. I have not seen these anywhere else.
Old 4th April 2015, 02:41 PM
Sorry for the delay on this.
I used an IR thermometer today to measure the temp of the boot LED
Ambient was circa 20 degrees C, after circa 1 minute operation, the hottest part of the bulb circuitry peaked at 70 degrees, the holder itself was, at worst, warm to the touch and the hottest part of the bulb was the contact pads where it appeared to acting as a heat sink.
I didn't see anything to worry me unduly.
1988 Audi 90 2.2E
2011 Mercedes E250
Old 5th April 2015, 11:27 AM
Hi Duffy,
Thanks for the detailed result, really interesting.
I have been playing with various LEDs but without any kind of thermometer, unless you count a slightly burnt finger tip.
Varying results, even with the same type supplied by the same supplier.
I think that my results might point to lack of proper research prior to mass production.
I have stopped messing about now because the ones supplied by Trups have fulfilled my needs.
Old 11th June 2015, 06:54 AM
Johnmed's Avatar
Does anyone have any idea if the D4's LED's would fit the D3?
Would be interested to know if you could retrofit some OEM+ goodness into the D3...
Old 7th March 2017, 08:42 AM
1781cc 1781cc is offline
Thread resurrection - anyone have a guide on how to get the roof interior light out as the bulb has died? its the white plastic driver side cover that I need to get out but dont want to damage the trip
Old 7th March 2017, 09:21 AM
Front
Pry the plastic diffuser from your side not the windscreen screen and it will pop open
Rear
Pry the entire unit starting from the sides and it will drop open.
