Old 2nd January 2013, 12:27 PM
Iyole Iyole is offline
Fronts are all Plastic .... Inner and Outer lens including the Fogs...
2002 S8 D2 F/L
Old 2nd January 2013, 12:31 PM
Thats the question I was just going to raise. Both the main light lenses and the fogs look like glass, sound like glass and feel like glass sio i was wondering how the PlastX would work so well
Old 2nd January 2013, 12:34 PM
I'm pretty sure the PF ones (like wot eye ave) are glass.
(indicators are definitely plastic though)
Old 2nd January 2013, 01:44 PM
Having just done a thorough check - scratch check using different grades of stuff - the main lenses are, indeed, plastic. Hard plastic, but plastic all the same.
Old 2nd January 2013, 02:08 PM
Can't comment on the PF but the FL is Plastic as stated and the fogs are
a VERY Hard thick plastic. Have tried to sand and polish by hand but not achieving the desired result.....
Even after raiding the SO's Make-up bag (undercover I might add) and findig
a rather coarse emery file ..... still made very little effect to the stone chips ...
So mechanical Sander will be used when I am back home ...
2002 S8 D2 F/L
Old 2nd January 2013, 02:35 PM
Originally Posted by Iyole View Post
Even after raiding the SO's Make-up bag (undercover I might add) ...
I hesitate to think what "undercover" disguise you might have used You think she may have let you off if were dressed in her clothes??
Old 2nd January 2013, 05:44 PM
OK so plastic front and back but very different types of plastic surely? I just don't want his Lairdship to attack the rear lenses in the same way if they cant take it, just have a feeling its very different plastic thats all
Old 2nd January 2013, 07:18 PM
I am sure you are right. The rear lenses are easy to scratch/chip and do seem to be a softer plastic. I seem to remember that 47p2 showed some excellent before/after shots of his Range Rover rear lenses after treatment to remove really bad scratching (cant find the thread though).
Old 2nd January 2013, 07:47 PM
Removal of Inner Lens ...
There are four clips that are part of the Lens .... two top and two at the bottom ....
Take care when lifting the clips .... very brittle ....
Take note of the gap between the lens and the housing .... obviously for heat dissapation ....
I was concerned when re-fitting to see the gap only to realize that it is there for a reason....
Note the discolouration (brown) of the Inner Lens. A good polish with the PlastX cleaned up about 90% of this.
I read many comments regarding the reflectors and the feeling that these are no go zones.
As can be seen below there is a fog mark on the reflector.
I proceeded to wipe this with a micro-fibre cloth without any dire effects and then proceeded to clean
all the reflectors gently with the micro-fibre cloth.
I then started cleaning the Inner face of the Outer Lens with the PlastX .... with amazing results ....
The cloths below indicate the extent of dust/soot etc that builds up on the Inner surface of the lenses
and on the reflectors .... blue cloth (lenses) ... orange cloth (reflectors)
This leads me to the question of wether Xenons emit a Gas etc which creates the almost carbon-like
build up inside the Headlamp .....
2002 S8 D2 F/L
Old 3rd January 2013, 07:06 AM
What's the rationale for using PlastX and ScratchX in different places? Looks like I may need to order another product!
