Thanking you muchly
if it helps Paul W replaced it without removing the timing belt.
http://forums.quattroworld.com/a8/msgs/15075.phtml |
Thanks Goran . I have the 32v so getting to it not a problem getting the bolts out is. I've ordered 2 new bolts and tomorrow i will take the cold chisel to it i'm just hoping the head doesn't snap off or i'm screwed
Don't you mean bolted?
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
Hmmmmm
Well i got them out with a cold chisel and hammer result. New thermostat in all put back together topped up with coolent and she's dripping. Strip down again today
Dezzy, Similar symptoms with mine; it was the sender - 5 minute job
Thanks mate i'll give her a go and see if the thermostat has fixed it if not sender The thermostat that came out has audi on it so it's either original or someone replaced it with genuine parts.
