Old 22nd March 2017, 06:47 AM
Johnmed's Avatar
Johnmed Johnmed is offline
Wow, I have NEVER had this in >5 years of ownership and use it a lot.
Is it dynamic route guidance settings?
I have dynamic route enabled and voice set to OFF Never had this either.
OP, do you have an iPhone or something attached? Only ask as if on mute the iPhone quitens briefly when you receive a notification.
2007 Mini Cooper S R56
Old 26th March 2017, 08:10 PM
I managed to capture the issue on video, just figuring out how to post it!!! I'll be back!
Old 26th March 2017, 08:12 PM
Let's see if this works...
File Type: mov trim.0AAFB738-729D-46ED-B377-A070EEC8E860.MOV (4.66 MB, 287 views)
File Type: mov trim.C2FA20B1-D480-4A0B-838D-D463E914A624.MOV (3.65 MB, 289 views)
Old 26th March 2017, 11:22 PM
1/ Press: Navigation
2/ Press: Setup
3/ Scroll down and select: Voice Guidance Off
The first two are amongst those the buttons to either side of your gear selector
Failing that, replace car
Old 30th October 2017, 12:55 PM
Conquistador's Avatar
This must be a 3G MMI feature as I've not come across this in any D3 with 2G MMI.
The live traffic updates (using the 'INFO' button) are pretty crap from my experience and not worth bothering with, in the 2G cars at least. They don't give enough detail and never seem to be local let alone accurate.
As you mention, Waze (made by Google) is a decent app and simple to use but I find Google Maps more than adequate and always accurate. Of course, getting a decent GPS signal through the infrared-reflective glass is another challenge altogether.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 30th October 2017, 03:49 PM
I still haven’t resolved this. I gave up.
I can completely silence it via pre set volume for sat nav instructions but it means you get 5 seconds of muted stereo each time the sat nav updates in the background, which can happen a lot if there is disruption on the route, M25 for example!
Old 7th November 2017, 08:47 PM
Ah, is it MMI 3G? Even the lady's voice is not the same as my 2G.
Old 10th November 2017, 06:51 PM
Yep it’s 3G and it’s annoying. LOL
