Old 21st June 2017, 07:59 PM
David, I am not upset in anyway, my banter knows no limits, I just don't show is as it's too much for most people
I knew you would be OK with it ...... But what about the picture?
Old 26th June 2017, 03:14 PM
diplomat2.6 diplomat2.6 is offline
OK, so
Rear glass. These are just pushed in, but dont grab just one corner, get all 8 fingers tucked in and start pulling gently.
Quarter glass. This is where you need to open the rear door and start from the bottom by sliding a long flat head screwdriver, wrap the end with a tape, ideally cotton tape, 2-3 layers. DO NOT pry too hard !!! If you bend it too much, and there is not much tolerance, chrome will go funny, will look crap and banding it back won't help.
At the bottom you have two clips and on the curved side 3 clips. When you undo the bottom ones, you will be able to do this by hand from now on, but again, be gentle - you will kind of have to find your own way of doing it, my way works and no damage done.
Door is a little time consuming.
You will need the glass out which is possible without removing the window frame (I did this on Saturday), but its a bit tricky.
Remove the door card.
Unscrew the window motor and remove.
Remove two black rubber caps at the top of the alu panel.
By hand slide the window down until you see 2 torx bolts.
Undo them and push the window back up.
Window guide/track on the door hinge side has two bolts fixing it onto the door shell, remove only the bottom one (Torx).
When you do that remove the rubber seal as far up as possible from the track/guide before sliding glass all the way to the bottom. It will require a little force to jump over the kinked seal.
Then by pushing the track out of the way a little and playing with the glass you will end up with a free glass inside the door.
You want the door latch side top corner to come out first, it wont work the other way round.
They behind the chrome trim you will see plastic push pins securing the trim, there is 5 of them.
You need to first pull out the middle pin in order to release the clip, be slow and patient, they are easy to loose forever inside the door.
One end one is tricky, but with torch you will be able to get to it.
Otherwise you will have to remove the entire window frame and then realign if you don't want to do it my way.
I will get you pics off all them in 10 minutes so you can see where the fixing points are as I am changing my trims as well as we speak.
Thank you ever so much - that's really kind of you!
Old 26th June 2017, 03:15 PM
Until someone with hands on experience have a look here for repair manuals.
It will most likely be in body repair sections
That's really helpful - thank you very much
Old 26th June 2017, 03:16 PM
I would imagine THIS DOCUMENT should cover it
Thank you very much - very helpful
Section 2.3 for the quarter glass trim
Not sure where the doors are in the doc, but the strip for those is riveted on from the inside iirc. You need to remove the window frame from the door shell and then drill out the rivets.
Thank you!
Old 12th July 2017, 12:12 PM
Have done the windscreen trim and the rear quarter D-pillars with the set of trim removal tools suggest above. £15 well spent.
As stated, the rear window chromes are not in the manual. I have had a look at the new/used on ebay, and they don't seem to have any rivet holes and look as though they might just clip on.
Will keep exploring and report back!
Old 12th July 2017, 12:23 PM
Here is one - no holes to fix on.
http://www.ebay.co.uk/itm/Audi-A8-D2...cAAOSwkttZYYca
Old 14th July 2017, 11:48 AM
Problem solved
I emailed our sponsors to ask and they looked at a spare they had for sale, as well as asking one of their mechanics. Knowing they had a spare for sale for £22.99 and them confirming that it is just a push fit, I opened the rear window and gave one end an extremely firm pull and it lifted the end slightly.
I then used a trim removal lever on the inside to gently lever it and it eventually broke free.
It doesn't look too distorted although it is covered in flaky blue paint.
The problem became obvious once it was removed. It had been put on when the paint was wet and this 'ruffled' the partially cured paint, causing it to act like glue. It has also dug into the top of the door so that needs be be carefully flatted. Still, all mostly sorted.
Now for removal of the rear bump and aerial before I prepare for painting next week.
Hoping to get it ready for Audis in the park
