Old 26th June 2017, 07:18 PM
North2007 North2007 is offline
Default DIY Westfalia Towbar Install - No Pre Installed Loom
Hi Guys, I am trying to install a old WestFalia 4E0907383A into my 2003. It doesn't appear to have a plug in loom for the control unit. I need to break in the loom to connect the 9 wires. Has anyone done this before or can advise? Regards Steve
2003, A8 D3 4.0 TDI
Old 30th June 2017, 07:06 AM
27litres's Avatar
27litres 27litres is offline
I haven't done a D3 before, but I have installed towbars on a number of cars.
The most relevant is the D2.
The official wiring kit for the D2 is obsolete, and can't be found.
I'm not sure how advanced it was in relation to the ECU/ESP, but I expect it would disable the parking sensors, which mine currently doesn't and is a pain whenever I reverse a trailer!
If you can get a factory loom for a D3, I suggest you do, as manufacturers quite often do a lot of work on towing kits to tie them in to things like the stability program and parking sensors.
If you can't find one, you will need a relay box - these are small and inexpensive and can be had from towbar installers and caravan places. They are needed to keep the trailers' electrical drain off the lighting circuits (thanks to bulb warning). You will need to find a suitable ignition switched live circuit and tap into it (dual fuse taps are good for this).
You will need to tap into the lighting circuits at the rear of the car. The D2 has a great feature here in that the lights themselves have spade terminals for each of their circuits making tapping the lights extremely simple!
I'm not sure what you use your extra pins on your trailer plugs for (we only have 5 or 7 pins on our plugs), but you will then need to tap into any additional circuits as required and couple to the relay box.
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 30th June 2017, 07:56 AM
I don't think and D3 came pre-wired. The factory bar is Westfalia as is the ECU, they do a retrofit loom and ECU kit which is identical in function which you can see here.
You can download the instructions as a PDF to see what is involved
Old 30th June 2017, 10:47 AM
NOR_KNet NOR_KNet is offline
Have you read this thread on audiworld? Maybe it could be of any assistance.
https://www.audiworld.com/forums/a8-...t-1-a-2848793/
Old 8th August 2017, 08:34 PM
Thanks Guys, Ive used a add on smart box in the meantime until I get time to sort.
2003, A8 D3 4.0 TDI
Old 1st September 2017, 10:56 AM
UPDATE: I've successfully installed the orginal trailer controller into the my D3. Benefits include: automaticity switches to towing mode (when plug is attached), in dash trailer turning signal.
Using a7pin, plan to upgrade to 13 pin in future.
2003, A8 D3 4.0 TDI
Thread Tools
Display Modes
