Old 14th November 2017, 08:50 PM
Zip's Avatar
Zip Zip is offline
Question RNS-D doesn't know where I am
The nav has been having a wobble. It can't find its own location....can't find any satellites. Is it the aerial? Worked for about 150miles on Saturday, then got confused coming up the A3.
Thanks,
Zip
Old 14th November 2017, 08:58 PM
HPsauce HPsauce is online now
Almost certainly a failed aerial.
Fairly easy to buy a cheap "puck" aerial (the powered-up-the-cable type) and connect to the RNS to test.
Deciding where to site it, on a double-glazed S8, isn't necessarily that easy though.
I found a solution a few years ago, but it involved soldering connectors in/around the boot (reference here: http://forum.a8parts.co.uk/showpost....91&postcount=8 )
Here's a close-up of it installed (on my previous S8). This location works fine and is effectively almost invisible.
I elected (at that time) to tap into the existing aerial wiring in the boot lid, but now I know more about the internals of an A8 and where to run cables, I would probably try to run the cable (with extensions if required) directly back to the RNS.
Last edited by HPsauce; 15th November 2017 at 11:51 AM. Reason: Additional wiring route comments.
Old 24th November 2017, 12:26 PM
Almost definitely the aerial, but fitting a replacement oem one would be my first choice.
If you have a common colour, a8parts may well have it on the shelf, otherwise they're not too difficulty to swap the internals of a new one over into your bodycoloured case, which I've done before.....
Old 24th November 2017, 12:32 PM
I agree.
But I was really just talking about testing, to confirm the problem.
And as for my solution, that was well before I was aware of A8parts, and may even have been before they started...... (When was that Ian?)
