Old 1st April 2014, 08:17 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default Arm Rest Removeall
Does anyone know how to remove this?
[center]
06 3.0TDI Quattro:
Options:
Old 1st April 2014, 08:44 AM
I've got a feeling that it may well be built in to the "tub" shaped receptacle that drops into the rest of the centre console so you may well need to source another tub if you want rid. call A8 parts and ask David there or Carl as I'm sure they will know for sure and may even have an alternative tub
Old 1st April 2014, 09:27 AM
It is built into the tub.. You 'could' get it out, but you'll be left with a big hole there, easier just to source a tub that hasn't had phone prep if you can.
Old 1st April 2014, 10:46 AM
ScottD3's Avatar
Its mainly the tub I want out.
I'm keeping the phone system (just ordered a cradle and matching phone) but its fealthy and want to give it all a clean. I've done the front half and want to do the back half.
Looking at it, I need to take the arm rest out and not sure how.
[center]
06 3.0TDI Quattro:
Options:
Old 1st April 2014, 11:02 AM
Isn't the armrest pillar a taper fit, just like the D2? Gentle taps upward to release if it is.
This is vaguely relevant: http://www.audipages.com/Tech_Articl..._remove_D3.pdf
Old 1st April 2014, 11:17 AM
ScottD3's Avatar
There don't appear to be any thing holding it down or any mention of it.
I thought the twin arm rest was standard.
so grap it on both sides and lift it up?
[center]
06 3.0TDI Quattro:
Options:
Old 1st April 2014, 12:25 PM
It's definitely bolted down... pretty sure you have to take the armrests off and the tub just pops up.
Old 1st April 2014, 12:28 PM
ScottD3's Avatar
How do you take the armrests off? lol
I found something to do with the D2 where you got to take the sides apart but I don't want to start pulling random things and see what gives.
[center]
06 3.0TDI Quattro:
Options:
Old 1st April 2014, 12:32 PM
After you've popped the trim off and undone the bolt of course.
Probably similar for D3 as that also has a chrome trim: http://www.wolfautoparts.com/4e08642...ver-37950.html
Old 1st April 2014, 12:33 PM
audifin audifin is offline
this might be helpful http://www.audipages.com/upgrades/phonecradled3.html
