Old 5th September 2018, 04:28 PM
Regulus Regulus is offline
Indeed it is riveted to the door.
Here is a better photo of the whole mechanism for the right rear door
Johannes
_________
A8 32V engine
Jeep Grand Cherokee -98
Old 5th September 2018, 04:56 PM
Thanks Johannes. It's presumably that big white pulley that has broken.
When I come to swap the frame over do I start with the window glass up or down or in between? At the moment I can move it so I'll get it to the best position before starting work (though that won't be for a few days).
I presume it's necessary to remove the frame first, then take the glass off it, fit to the new frame and refit everything.
Sounds so simple...……..
(Must remember to get a load of clips for refixing the trim, hopefully A8parts will have some)
Old 5th September 2018, 05:39 PM
I am actually not sure what position will be better.
I removed and refitted it with the window closed, and that made the whole frame easy to handle.
You can connect the wires while the frame is off and lower/raise the window.
Have a look at these photos and see what you think?
That is correct
ID:	20067   Click image for larger version
Johannes
_________
A8 32V engine
Old 5th September 2018, 05:47 PM
Thanks Johannes.
How does the glass come out, is it just one bolt securing that black support to the mechanism, then slide down?
Old 5th September 2018, 05:55 PM
Yes there is only a plug with a clip, and one guide on each side in the window itself.
Mind the wire going to the door lock though. I struggled fitting that again.
Try to leave it in the door lock mechanism, and remove it in the end where you found the black thingie
Edit: Lower the window fully and remove half the holder in the bottom, to get the window out. The holder is 2-parts, one on the inside, and one on the outside. Then wiggle the glass out
ID:	20069   Click image for larger version
Johannes
_________
A8 32V engine
Old 5th September 2018, 06:14 PM
When the frame is fitted to the door again. You will probably have to adjust the window a bit to get it to close properly. Adjust it in the bottom where the black support is
Johannes
_________
A8 32V engine
Old 6th September 2018, 10:02 AM
Thanks Johannes, presumably it's easier to do that adjustment before fitting the frame back on the door?
Just had a nice chat to Maria at A8Parts and ordered the necessary, plus a couple of little items I've been thinking of for a while.
Too big for overnight delivery so should arrive Monday, at least my weekend will NOT be spent working on the S8.
Old 6th September 2018, 05:33 PM
I would believe it is easier to adjust with the frame back on the door.
Maria at 8parts is great
I am in the process of ordering some items as well, from a breaker here in Sweden. But they do not have all the parts I need. So I will be making an order from 8parts as well, looks like
Johannes
_________
A8 32V engine
Old 7th September 2018, 09:49 AM
Or maybe it will.
Definitely shipped as a "48-hour Large" item and collected yesterday.
BUT it's made it to my local depot overnight and is now out for delivery, expected about 2pm this afternoon.
Edit: Arrived safely. Courier was very surprised how light it was when I explained it was a large section of a car door, made of aluminium.
Old 10th September 2018, 12:52 AM
27litres's Avatar
27litres 27litres is offline
Dont forget to lubricate the runner slots as well as the window channels Andrew, makes a huge difference to window load/speed
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
