Old 14th July 2020, 12:15 PM
C4R 100N's Avatar
C4R 100N C4R 100N is offline
Default Posting an interesting manual transmission conversion thread.
Click here for more information
I really admire the dedication demonstrated here!
1998 D2 S8 Jaspis Green
Old 14th July 2020, 01:43 PM
Stromaluski's Avatar
The owner just posted that over on Quattroworld. I bookmarked it to make sure I read through it later.
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
2010 Jetta TDI Cup Edition
Old 14th July 2020, 04:45 PM
Found this to be an interesting tid bit from that thread...
But I did find that Energy Suspension 3.1108G GM TRANSMISSION MOUNT would work with some spacers.
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
Old 14th July 2020, 05:25 PM
Pricey things over here though. Cheaper to modify B5 mounts instead.
Old 14th July 2020, 06:00 PM
More info on modifying B5 mounts? First I've heard of that.
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
Old 14th July 2020, 06:57 PM
Wolfinsheepsclothes did that for his manual swap, although he used an 0A3 gearbox and Skoda mounting brackets, but the principle is the same. They just need a riser fabricating which is two oval flanges and a tube in the middle to lift them up to D2 height. The advantage of this being that they are weighted properly for the 01E, and the height can be adjusted so the drivetrain sits level. Putting an 01E on the stock 5HP mounts means it sticks up at the back about 1/2" due to the huge weight difference.
On the manual I built I took the phenolic spacers off the top of the OE mounts which helped a little, but on the next one I will use the B5/C5 hydro mounts designed for the 01E, sitting on risers, then I can set the height to wherever I want. The risers are trivial to build with a CNC plasma and mig welder
Its a decent write-up from Alex actually. You guys are lucky to have so many C4s kicking about to donate parts (ie more than the none at all we have here!). I had to use a highly modified B6 shifter which was a bit of a pain, especially as I lost the drawings for it. I can get new OE front shafts, which is a bonus, but I can't get propshafts which you guys can get from Advanced Automotion (impractically expensive to ship them over here). Still, I have a few genuine manual propshafts stashed away which is all I need
