Old 25th January 2021, 02:04 PM
I was having water pouring out when opening the boot after heavy rain. It was coming in through cracked reverse lights so have also replaced them thanks to A8Parts.
I'd had the same issue but had found some new inner light units and bought them a year before so we swapped them over at the doctor's when my steering rack was swapped
MJ also dealt with the exact levelling of the boot shut lines which was a black art involving all kinds of witchcraft!!
ID:	25297   Click image for larger version
ID:	25298   Click image for larger version
Old 26th January 2021, 07:04 AM
johnny_quattro's Avatar
Ah, thanks for that nugget of info. Both of mine had cracked a while ago, and I have already replaced them once.The white lens does appear to suffer weakness, compared to the rest of the inner light cluster. Looks like I'll have to address both problems but I'll look to change the rear lights first before looking at the number plate surround.
John G
Old 19th February 2021, 01:54 PM
CaifanSC CaifanSC is offline
Are you applying a film to the tail lamps to prevent water ingress? Could you tell me a little bit more about it and what kind of film you used, please?
Audi V8 Quattro Original 5speed - Black/Black
Audi S8 - Avus/Oxblood
Audi S8 - Cashmere/Twist
BMW 850i - Red 6speed
BMW 850Csi - Red 6speed
Ford Thunderbird x 3 Supercharged & 5speeds
Mustang convertible
Range Rover Autobiography - BRG/English Tan
Old 19th February 2021, 01:55 PM
[1] Brake block upgrade (installed)
[2] Boot lid grommets upgrade (both installed)
[3] Glovebox LED light upgrade (still to do)
I just bought two sets of grommets for both of mine...but could you tell me where you acquired the brake block upgrade and the LED set?
Mustang convertible
Old 19th February 2021, 02:05 PM
Thank you. The grommets are printing now and will ship on Monday.
I also make the UK version of the brake block and the LED glovebox lights, but they aren't listed anywhere other than the relevant threads on this forum. I don't know for sure if our brake block fits LHD cars since it was developed on RHD models, but I think it is still available in the US anyway. PM if you'd like a glovebox light tho
Old 21st February 2021, 03:13 PM
PM sent!
Mustang convertible
Old 22nd February 2021, 08:31 AM
No the film you can see is just protective film on the new tail light which is then peeled off once you've fitted it
