Go Back   A8 Parts Forum > Our Other Audi Friends > Other Audis
Other Audis All other Audi related chat
Old 19th June 2012, 09:28 AM
Default 2013 Audi SQ5 TDI
At the risk of upsetting the purists. . . .
2013 Audi SQ5 TDI
In conjunction with the 24 Hours of Le Mans, Audi is presenting the new top model of its recently revised Q5 model series - the Audi SQ5 TDI. Boosted by two turbochargers, its 3.0 TDI produces a brawny 313PS and 650 Nm of torque between 1,450 and 2,800 rpm. The Audi SQ5 TDI will roll into dealerships in the first quarter of 2013 and is the first S model in the history of Audi with a diesel engine.
The powerful TDI, which displaces 2,967cc, uses a twin-turbo design in which the two turbochargers are connected in series via a flap. Cylinder head cooling, the timing and lift of the intake cam shafts, the pistons, their oil-jet cooling and the piston pins have been specially designed for the high-performance concept. The common rail system develops as much as 2,000 bar of pressure and injects as many as eight shots of fuel into the cylinders per cycle. The 3.0 TDI biturbo has a great sound. This sound is further modulated by a sound actuator in the exhaust system - a loudspeaker in short side channel.
The Audi SQ5 TDI sprints from zero to 62 mph in just 5.1 seconds, its top speed electronically limited to 155 mph. A fast and smooth-shifting 8-speed tiptronic and quattro permanent all-wheel drive with torque vectoring transfer the power of the brawny V6 diesel to the road.
ID:	3884   Click image for larger version
ID:	3885   Click image for larger version
ID:	3886   Click image for larger version
ID:	3887   Click image for larger version
ID:	3888   Click image for larger version
