Old 27th April 2011, 08:26 PM
Diablo Diablo is offline
Default My lopsided A8 - any suggestions?
Hi All,
My 2005 3.0TDI sits lower right rear corner. All four corners go up and and down when the suspension settings are altered, but that corner always appears to be lower by a consistent amount? Any thoughts are welcome.
Thanks in advance.
Old 27th April 2011, 08:37 PM
The last 2 posts in this thread may cast some light.
Old 27th April 2011, 09:08 PM
Hi,
I did read thorugh the other posts, but not being that technically minded, I am still slightly at a loss. The suspsions goes up and down OK, the ride stiffens and softens and there are no warning lights coming on???
Any thoughts?
Old 27th April 2011, 09:13 PM
If one of the suspesion ride height arms is broken, one corner may think its at the right height when it isn't.
Old 27th April 2011, 09:25 PM
If it is one of the arms, is the main dealer the only source for these? Are they expensive?
Thanks again.
Old 27th April 2011, 09:31 PM
try the ones from the thread if one of yours is broken, there adjustable!
Old 27th April 2011, 09:53 PM
I will contact them tomorrow. Really appreciate the help
Old 6th July 2011, 02:26 PM
I had my car checked over and there is no evidence of any broken suspension arms etc. Any other suggestions, please? Someone did mentioned that it may need resetting on the Audi diagnostic equipement?
Many thanks.
Old 6th July 2011, 02:33 PM
could be that the settings for that corner are out.. it can be reset by VCDS or the dealer
Old 6th July 2011, 03:14 PM
VCDS has to be the next step. I will try that and let you know what comes of it.
Many thanks.
