Old 17th March 2012, 06:41 PM
I guess it depends on how the button is wired in to the opening mechanism.
The A7 and possibly A8 D4 kufatec thingy simply uses the signal the switch on the boot lid sends to close it but remotely links that via a circuit board and transponder to the key push button. Give craigyB a call and he can probably tell you straight away. His web address is http://www.tclsatnav.com
Old 17th March 2012, 06:45 PM
dont know, i think i still have an installation manual, but its on another machine, will post it up tommorow, may tell you more
Old 17th March 2012, 06:48 PM
It would be good to know if this works as I also have a button on the drivers door in the A7 and was going to get the Kufatec unit
Old 17th March 2012, 06:50 PM
thanks lads, think if i can crack this one then it will serve a couple of people well
Old 17th March 2012, 06:51 PM
I will have to test drive your W12 as well to compare if both boot mechanisms are working the same. Ahemmm....lol
Old 17th March 2012, 06:55 PM
Fair Play Neil thats got to be the most entertaining thing you have sed for a while, nearly fell off my chair with laughter
im sure i can let you have tickkle of her
Old 17th March 2012, 07:16 PM
The wire for the close button runs to a different connection from the main button. Though, a bodge with 'key number 3' might work in conjunction with the kufatec unit
Old 18th March 2012, 10:41 AM
heres the installation manual, looks quite simple to do. actually sounds like a good idea to do this, i dont know how many times ive put the keys in my pocket and started walking away when the boot suddenly starts opening.
the key would now need 2 quick presses which may be better
heres the install manual from kufatec
33801;hatchback interface Audi A8 4E (englisch).pdf
Old 18th March 2012, 10:47 AM
Looks like it splices into the boot button wire. Not too painful to install.
Old 18th March 2012, 10:55 AM
Scotchlok would sort that out with no soldering.
