Old 5th December 2014, 11:48 AM
3.7 slp 3.7 slp is offline
Default 2014 Sat Nav disk with 0770 software?.
Hi Just a quick one all
Just to see if anyone would know it the new 2014 disk would work with my current SW of 0770 which is very old. Told that it should but would just like to check before ordering. I have a set of Update disks to use at somepoint.
Also about to order the 1100 update disk as I don't want to jump to far with the updates.
Planning to do it when its a bit warmer outside, but would still like to use the new 2014 disk....not to worried about 3d on the maps right new.
Thanks very much
ALL
Old 5th December 2014, 01:08 PM
Satnav disk should work.
Old 5th December 2014, 05:06 PM
I read on a German forum before it was released that there was an Audi note that said it requires 5770.
Old 10th December 2014, 08:08 AM
Yep was not sure I did check with the seller and he thinks it sould be ok with the old SW 0770. I will update at somepoint next year .....a warm summers evening sounds like the best time I think.
Old 21st December 2014, 07:11 PM
Burnzybubbles's Avatar
I updated mine and I was originally on 0770, satnav worked fine if a little slower but that dissapeared when updating to 5570, you will still not have 3d maps though untill the mmi is updated.
