Old 19th June 2018, 10:30 PM
1cc 1cc is offline
Default Audi a8 d3 3.0tdi 2007 throttle valve fault
004203 - Throttle Valve
P106B - 001 - Stuck or difficult to move - Intermittent
Noticed this ticking for a few seconds from the engine after i turned it off this morning. vag'd it this evening when i got home and it produced the fault above!! any advice??? also see the video below.
Old 5th July 2018, 06:15 AM
That's not the throttle valve, that's the EGR Cooler changeover valve.
The throttle valve is one the larger silver part somewhere above the dipstick.
Old 5th July 2018, 08:09 AM
1cc 1cc is offline
Default Egr
Yeah your correct, I got it fixed. The gears had worn that control the throttle valve so I got a throttle valve repair kit (basically two plastic gears) £30 and fitted them, problem sorted.
ID:	19660   Click image for larger version
ID:	19661   Click image for larger version
Old 20th July 2018, 03:11 PM
Well done - where did you get the cogs from? I have never seen that.
I don't know what is wrong with your cooler flap, Mine used to do that and when I investigated the whole thing had fallen apart inside and had to be replaced, not sure if that's why it flapped back and forth like that and not sure if it still does that.
Old 20th July 2018, 10:37 PM
I had the same cog wear out on my old D3, I couldn't find parts and was tempted to buy a throttle body off a golf to see if the cog was the same (much cheaper than an A8 one, but a different shape!) but in the end bought a pair of throttle bodies of a German breaker that only have 30k kms on them and just swapped the full units.....
Still have the "spare" good one in the garage (and likely the broken one also)
Old 21st July 2018, 08:09 AM
1cc 1cc is offline
Bought them from manifold kits uk via ebay, the exact part code was different to what they had listed but took a chance and they fitted fine. Little bit of work getting the half gear off had to gently grind top surface down with flap disc but it was an easy enough job.
https://www.ebay.co.uk/itm/THROTTLE-...G/132375314664
Tags
fault, p106b, throttle valve
