Old 31st October 2016, 10:06 PM
goldsax goldsax is offline
Default drivers side seat switch issue
can i confirm my thoughts.
drivers seat does not come forward when i push the seat adjustment switch forward.
however the seat comes forward if the memory button i pressed.so i know the motor is ok.
i presume that it must be the switch.
1) will the switch need replacing?
2) easy job?( prefer no two take the seat out)
cheers raj
Audi S8 2002
Old 31st October 2016, 10:30 PM
Well, I've had one 8 for a short while where switch wasn't the issue, it was the ECU which is about £80, easy to change but it will throw CP which is £60 on top, but easy to change.
Get a ratchet with a spline bit, can't remember what size, undo all 4 bolts on each seat which is really easy, tilt them back to gain access to ECUs, swap them over (passenger/driver) and see if it goes forward using switch, if it does then it is the ECU , if it doesn't then switch it is.
I've never changed a switch on them, but can't see it being a big job.
Old 1st November 2016, 09:30 AM
thanks for the info re. ECU
nothing ever plug and play with a D3.
another weekend job .
thanks again raj
Audi S8 2002
