Old 12th July 2016, 02:23 PM
5 hours!? You still on dial-up down there in Devon Mike?
Takes me 10-15mins to download them typically.
In plymouth I had Virgin 150Mb. Here on Dartmoor I have smoke signals.
Old 12th July 2016, 02:31 PM
You should check to see if IPoAC is available down there; might be faster than what you have
Old 12th July 2016, 02:59 PM
and no choice of provider? I don't get a choice and if the other 5 houses are using the internet just as well switch it off.
Anyway, i'm surplus to requirements in PNB and finish next week so if you still wanted a digger and driver for a few days pond digging i'm available.
Old 12th July 2016, 03:20 PM
I can get ISOs from MSDN if needed. I'm just up the road a bit near Crediton
We're lucky to get electricity down here let alone that new fangled interwebs. I can't even get mains gas
Old 15th July 2016, 08:47 PM
Cool. Ill give you a call next week.
Old 15th July 2016, 08:52 PM
Sooooooo,
I've successfully downloaded the ISO using the link. Buuuut the windows USB bootmaker doesn't recognise it so I cant make a bootable USB from it.
So back to needing an ISO for Win 7 X64 N.
Can you help Scott?
Old 16th July 2016, 02:06 AM
Which one did you download, I downloaded 10 and 7 from Microsoft servers using tool Mark linked to and they are working fine.
Old 16th July 2016, 07:13 AM
Sooooooo,
Well those ISOs definitely work Mike (using the Windows ISO Downloader); they're the original ISOs from Microsoft.
So, either they're getting corrupted or something's going wrong when you're making the bootable USB drive. Did you try the Rufus program I mentioned?
https://rufus.akeo.ie/
Old 16th July 2016, 12:50 PM
If it might be flaky downloads caused by a slow connection,download JDownloader to manage the download. You run it then copy the link for the file you want to download and it will be able to recognise any errors as you go
Old 21st July 2016, 08:00 PM
Finally sorted. Had to download the ISO 3 times using mark's link! then had loads of issues making a bootable USB to find my stick had some bad blocks. http://forum.a8parts.co.uk/images/smilies/mad.gif
New pen drive and I was away. PC back up and running. Thanks Guys an Gals
